risnerry
- 0
- Oct 16, 2008
knox,
Indiana
i need steps on how to replace the water pump.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Definitely! If that belt breaks, it can damage the cam timing belt. And yes, good point about the tensioner. Those things usually spring a leak by 60Kmi -- should be replaced when the timing belts are replaced.when you say replace both belts are you talking about the balancing shaft belt as well?
well im pretty sure its not the water pipe.. but this job sounds like it can be a real pain. i wasnt really sure how to replace it and if i could do it myself and save a couple bucks. but the way it sounds i might just take it to the shop and have it done.
I am about to do my belts and water pump, just wondering if you guys recommend any specific belts? or will just a cheapo from Napa be fine?
