How to PROPERLY break ball joints loose?
Posted by alice, Feb 7, 2012
Handling Tech - 4G63 suspension, steering, brakes, tires, lightweight wheels, bushings, etc.
  1. alice
    alice Proven Member
    DSM Profiles:
    Sep 7, 2006
    303
    Canandaigua, New_York
    On a 2g DSM or pretty much any car in general, what is the proper method of breaking a ball joint loose besides wacking it with a big hammer? I know there has to be a proper tool of some sort. I have always used a pickle fork and have always destroyed the boots so guys and gals, what's the right way to do this?
    #1
  2. LiquidX
    LiquidX DSM Wiseman
    DSM Profiles:
    Sep 19, 2008
    6,594
    91
    Anywhere, Pennsylvania
    Hammer time on this radio.
    #2
  3. Colt4G63 also
    Colt4G63 also Proven Member
    DSM Profiles:
    Jul 23, 2008
    2,670
    42
    Tonawanda, New_York
    Hit the knuckle with a hammer.
    #3
  4. dsmtun3r98gst
    dsmtun3r98gst Proven Member
    DSM Profiles:
    Jan 26, 2008
    485
    Westminster, California
    He(she?)is asking what is the best way to break it loose without the use of a hammer just in case you guys didn't read that part. LOL.
    But just in case you guys are wondering..... I also use the hammer method LOL.
    Here is the proper tool to use:
    #4
  5. alice
    alice Proven Member
    DSM Profiles:
    Sep 7, 2006
    303
    Thanks for all of the replies everyone. I just hate pounding on anything in my car with a hammer. I will look into that tool too!!
    #5
  6. bryanwheat
    bryanwheat DSM Wiseman
    Aug 16, 2004
    6,952
    156
    Columbia, Missouri
    It isn't going to hurt the suspension beating on it with a hammer if you do it right. People have been doing it for many many years. You are over complicating a simple situation. A 4lb mini sledge is all that you need to break and taper fit joint apart.
    #6
  7. dalesmitsu
    dalesmitsu Proven Member
    DSM Profiles:
    Jul 23, 2006
    346
    North Canton, Ohio
    Its made by OTC.
    #7
  8. shockey1013
    shockey1013 Proven Member
    DSM Profiles:
    Sep 21, 2008
    113
    Colorado Springs, Colorado
    One of my buddies used to work for Mitsubishi and he showed me the way they do it there. Just use a normal hammer and hit the metal surrounding the ball joint shaft. Too easy!
    #8
  9. Sebba
    Sebba Banned Member
    May 11, 2006
    538
    3
    Austin, Texas
    You follow the rule: Always hit what it goes through, never actually strike it.
    #9
  10. shockey1013
    DSM Profiles:
    Sep 21, 2008
    113
    Ha :thumb:
    #10
  11. ramsack
    ramsack Banned Member
    Dec 27, 2007
    2,196
    14
    West Lawn, Pennsylvania
    As others have stated, hit the metal around the taper of the ball joint, on the knuckle. No need for any useless tools like ball joint separators. They are acceptable when you have one that you don't care about and is absolutely trashed, and rusted in place. The reason most people can't hammer on a knuckle to get one loose is likely because they or the previous owner can't follow instructions, and they just torqued the nut to whatever the hell they want...usually to the point of grunting loudly.
    #11
  12. crash89
    crash89 Supporting Member
    DSM Profiles:
    Mar 5, 2008
    1,928
    71
    Janesville, Wisconsin
    Like you I always used to use pickle forks for ball joints and always tore the boots.. And as stated above numerous times, hit the knuckle (or surrounding area) of said ball joint with a decent size hammer a couple good times.. Pop right out.
    #12
  13. romeen
    romeen DSM Wiseman
    Jul 12, 2006
    2,434
    29
    Vancouver, Washington
    #13
    buddahboost likes this.
  14. eclipsekid1013
    eclipsekid1013 Proven Member
    May 9, 2010
    157
    hudson, New_York
    Fork. And obviously a hammer. And if that doesn't work a bigger hammer will.
    #14
  15. assassin3117
    assassin3117 Proven Member
    Sep 17, 2008
    75
    Raliegh, North_Carolina
    Hammer all they way. I use a 48oz hammer in the shop when i do then 1-2 wacks on the sweet spot and boom she is screaming daddy!!
    #15
  16. TSIMonsteR
    TSIMonsteR Proven Member
    DSM Profiles:
    Nov 23, 2003
    1,352
    8
    HP, North_Carolina
    :thumb: quoted for truth.
    It can be a real pain, so be patient. I swear you'll feel you've spent the day playing thor
    #16
  17. bryanwheat
    Aug 16, 2004
    6,952
    156
    Columbia, Missouri
    The way i look at it, if you need anything more than a hammer than you are doing something wrong, LOL.
    #17
  18. assassin3117
    Sep 17, 2008
    75
    Exactly Brianwheat!! Only time i use a pickle for is if the joint is completely seized then there's no choice but to break out the pickle and air hammer. I only had a couple cars come in the shop that were like that.
    #18
  19. DSMBanditFZ6
    DSMBanditFZ6 Proven Member
    Nov 17, 2011
    157
    Somewhere, Arkansas
    I use a crows foot. ( I guess a pickle fork) and use a small jack and a piece if wood to put just a tad bit of pressure on the hub. I then tap it with a hammer. You could put a rag in there, to protect your boot.
    Now if your working on an old car like my torino (the upper is pinned in) big PITA. I had to break out the grinder on that LOL!
    Good luck!
    #19
  20. ricktb
    ricktb Proven Member
    DSM Profiles:
    May 20, 2007
    432
    4
    Edmonton, AB_Canada
    It came time to do my balljoints... most of them were loose and clunky. I dreaded the thought of replacing them manually. So much labor and messy with the grease, bleeding knuckles, etc, etc. Then I found out you can buy a new control arm complete with fresh ball joint factory installed with grease and boot for $50-$100 each.. 2-3 bolts to replace the whole dang thing.. I replaced all 18 ball joints on my car and the hardest part was getting the old control arms off.. yes I had to grind some bolts off, but still much easier than pulling each and every ball joint apart and repressing.. you need like 3-4 specialty tools for that operation.. forget it just do the arms and you get fresh bushings at the same time..
    to answer your question I've seen a mechanic use a air-powered tapered fork of some sort, with impact pulses. I dont know the name of it but the air forces the fork between the ball and the joint and forces them apart. I suppose a clamp of some sort to re-press back together? Also you'll need a tool to re-press the boot back on... I tried this myself and used a extremely large socket, but the diameter wasnt right and it tore the rubber boot, and grease would leak out. FAIL
    #20
  21. bigjdog84
    bigjdog84 Proven Member
    Aug 8, 2003
    106
    6
    Lake Ariel, Pennsylvania
    A ball joint separator is the best to prevent damage.
    OR pickle fork and hammer as mentioned above, but it can gouge metal and damage rubber boots.
    #21
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
