how to make turbo spool faster
Posted by spawn87, May 25, 2009
Please Support Extreme Turbo Systems
  1. spawn87
    spawn87 Proven Member
    697
    Joined Dec 6, 2007
    sacramento, California
    i have a ported 14b with ss o2 housing and 3inch exhaust but im still not feeling pull till 3500 rpms... my question is how can i make it so it will spool or get it to pull faster?:hmm:
    port the hotside some more?
    tubular header?
    or a MAFT set up?
    Log in/Register to remove ads
    My DSM:
    1995 Eagle Talon TSi AWD
    14.468 @ 101.474 MPH
    Loading...
  2. My1GLaser
    My1GLaser Proven Member
    1,436
    18
    Joined Dec 4, 2006
    Bartow, Florida
    Search shimming the wastegate or something similar. It sounds like the flapper is hung open slightly. That thing should be in full boost by 3k.
    My DSM:
    1992 Mitsubishi Eclipse GSX
    11.420 @ 121.980 MPH
    Loading...
  3. habitatguy187
    habitatguy187 Proven Member
    2,590
    7
    Joined Aug 20, 2008
    Indianapolis, Indiana
    My non ported 14b spikes to 20psi at 2800rpms, check for boost leaks, if you don't have any then either have exhaust leaks pre-turbo or your wastegate is opening prematurely.
    Loading...
  4. Dsmj89
    Dsmj89 Proven Member
    2,150
    10
    Joined Nov 11, 2008
    Miami, Florida
    I agree with the guys above. Try spraying some wd40 around the wastegate flapper arm area, let it sit for 5 minutes, and take it for a spin and see if that helps unstick the arm.
    Those turbos as stated should be spooled around the 2800-3200 rpm range.
    If yours isn't spooling until after then you have some good pre-turbo exhuast leaks. Make sure all your bolts are nice and tight and that your gaskets aren't bad either.
  5. habitatguy187
    2,590
    7
    Joined Aug 20, 2008
    But it's more likely that you have boost leaks, do a boost leak test first, it should be regular maintenance on a turbo car.
    Loading...
  6. Dsmj89
    2,150
    10
    Joined Nov 11, 2008
    Miami, Florida
    +1. These intercooler hoses are old and worn down and tend to start tearing and cracking over the years of use. Do a boost leak test asap.
  7. jrohner
    jrohner Proven Member
    2,551
    9
    Joined Sep 25, 2004
    Willmar, Minnesota
    An exhaust/wastegate leak makes a lot bigger difference than any boost leak.
    Make sure you have no exhaust leaks, if you don't you may have a cracked turbine housing by the wastegate flapper. It could also be a boost controller issue, or your cam timing could be off.
    My DSM:
    1991 Mitsubishi Eclipse GSX
    11.415 @ 119.59 MPH
    1998 Mitsubishi Eclipse GSX
    414 whp   459 lb/ft
    Loading...
  8. spawn87
    697
    Joined Dec 6, 2007
    well i know its not the timing cause i just got everything done at a my friends shop... and when i ported the housing the cracks were minor but i might of ported the w/g outlet a little to much that could be the problem...:hmm:
    and i also know its not the exhaust cause i just had it checked and put new seals everywhere
    but i think if i shimm the w/g and spray it with wd40 it might be a good place to start
    i will boost leach tested tomorrow at work and let you know how it went
    thanx guys:thumb:
    My DSM:
    Loading...
  9. siceclipse
    siceclipse Proven Member
    933
    12
    Joined Jun 26, 2003
    FFLD County, Connecticut
    Ive got 5 bucks that says its a boost leak.
  10. toofast82
    toofast82 Proven Member
    2,614
    10
    Joined Feb 8, 2005
    Tinley Park, Illinois
    I'll pm you my Paypal account info:D
    But yeah as said do a boost leak test, double check there is no pre-turbo exhaust leaks
    Have you done any porting to the turbine housing or manifold?
  11. spawn87
    697
    Joined Dec 6, 2007
    i only ported the hotside of the turbo
    My DSM:
    Loading...
  12. toofast82
    2,614
    10
    Joined Feb 8, 2005
    I would port the manifold collector, like remove the step for sealing ring as well if its not done on turbine housing.
    Check out vfaq.com for some how-tos.
    Originally you said that you're " not feeling pull till 3500rpms" Could you be more specific in terms of psi/rpm?
  13. spawn87
    697
    Joined Dec 6, 2007
    what i mean by this is that i don't feel the turbo kick int till about 3500 rpm... i have it set at 15psi...
    i ran a boost leak and Nada everything is OK...so i shimmed the w/g and wd40 the actuator arm but have not ran it yet cause my radiator cap broke and need to get a new one... i will post on this later on today to see if i might have fixed the problem
    for what ive read i expect to feel the car pull at about 3k.
    My DSM:
    Loading...
  14. DyNamiC
    DyNamiC Proven Member
    65
    Joined Jun 17, 2008
    Cleveland, Tennessee
    Something is up, you should feel pull before 3k with the 14b. What psi did you test to when you did the boost leak test?
  15. toofast82
    2,614
    10
    Joined Feb 8, 2005
    Feeling pull and "peak torque" are two different things. Yes the 14b should spools very fast and should definitely hit full boost in 3-3500rpm area. Peak torque will occur later in the rpm band though.
    To the OP: What gear are we talking about? If you are at WOT at a low rpm, Where are you hitting your 15psi?
  16. spawn87
    697
    Joined Dec 6, 2007
    i tested the system to 18psi
    im running 15psi and i hit that at about 3200-3500 rpm
    after that i feel peak torque at about 4k
    so if what you say is true then im doing ok then:p
    My DSM:
    Loading...
  17. toofast82
    2,614
    10
    Joined Feb 8, 2005
    Sounds about right.
    You may be able to cut that down a bit with porting the inlet of turbo and collector of manifold. It may be hardly noticabe though.
    If you had a fuel/timing management system, you could tweak some more out of it, too.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
