How to Install a AEM Fuel Filter
Posted by 4g63telantra, Sep 13, 2006
Please Support Boostin Performance
  1. 4g63telantra
    4g63telantra Proven Member
    353
    Joined Dec 10, 2004
    Toronto,
    AEM FUEL FILTER
    When I was in store to replace the fuel filter in my race car, I looked no where else but to AEM for my fuel system. Already running a AEM fuel rail and AEM fuel pressure Regaulter, I went ahead and got myself a matching AEM fuel Filter. The AEM Fuel Filter does not only look great under my hood but it also delivers fuel up to 500 HP and has a replaceable filter element. The 6061 aluminum filter housing provides excellent durability and is double O-ringed to deliver superior leak protection and can be fitted to work with most cars. The filter case comes in 3 colours to match your engine bay and comes with all the hardward to be mounted into a Honda/Acura. To make this filter work with other cars, it takes a few fittings and alittle bit of space under the hood.
    This tech article will show you how to replace the stock fuel filter with a AEM fuel filter and the feed line to the rail using the -6AN fuel line/fittings.
    Approximate install time 1-2 Hours
    Testing your connections: Be careful of open flames, gas spray and wear eye protection.
    Depressurize fuel system by disconnecting the fuel pump harness and turning the car over till it does not start anymore.
    Disconnect the (-) size of the battery.
    Place paper towels under the fuel rail inlet flange.
    Remove stock fuel filter from the mounting bracket and fuel line from filter to rail.
    Place where you want the new fuel filter to be and cut your new -6AN fuel line to
    length that will go from the top of the AEM fuel fitler to the inlet side of the fuel rail.
    Install 2 6-AN Female ends on each side of the fuel line.
    Apply thread sealer/teflon tape to a -6an 4m x1.5 Female Saginaw adapter
    Install the -6AN straight swivel to the bottom of the filter housing.
    Take the bare end of the hose and route the way you want it to the new fuel rail inlet fitting taking note that the engine will move front/back on accereration so leave some slack.
    On the top of the AEM fuel filter, install a fuel pressure banjo fitting and a banjo take-off
    bolt with the new crush washers that are supplied with the filter.
    Place a fuel pressure gauge or a cap on top of the take-off bolt.
    Place the new fuel filter back into the old fuel filter mounting bracket.
    Run a new -6an fuel line from tank to the swivel at the bottem of the fuel filter.
    Reconnect the (-) of the battery and replug the fuel pump harness.
    Start the car watch out for any leaks from the fittings and filter.
    Part Numbers:
    AEM High Volume Fuel Filter #25-200
    Replacement filter (NAPA Gold Part #PN4950 or FRAM part #CH6069)
    Russel -6AN Fuel Line
    Russel Swivel Flare to Matric adapter #670520
    Russel Fuel Pressure Take Off Bolt #640700
    Russel Banjo Fuel Fitting #640910
    Russel Straight End Fitting # 610020
    Fuel Pressure Gauge (Any Gauge With a 1/8" Fitting)
    Log in/Register to remove ads
      File size:
      40.7 KB
      5,994
      File size:
      41.4 KB
      5,885
      File size:
      55.9 KB
      5,975
      File size:
      73.8 KB
      5,875
      File size:
      32.1 KB
      5,841
      File size:
      43.1 KB
      5,832
      File size:
      46.3 KB
      5,826
      File size:
      50.6 KB
      5,845
      File size:
      68.9 KB
      5,804
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
