How to Identify Rear Differential???
Posted by YoYo_4G63, May 9, 2011
Please Support Kiggly Racing
  1. YoYo_4G63
    YoYo_4G63 Proven Member
    182
    3
    Joined Sep 5, 2008
    Carolina, Puerto Rico
    Is there a physical way to identify any difference , between auto vs standard rear differential?
    :confused: thanks
    Log in/Register to remove ads
  2. Bud92gsx
    Bud92gsx Supporting Member
    7,823
    31
    Joined Jan 16, 2008
    Your moms house, BC, Canada
    Well if your swapping in awd to the mirage..You should prbably just find out what the donar car has for a transmission...The gear ratios are different so don't screw up and put in the wrong rearend..I'll run outside and see what kind of markings are on an auto rearend..
    Edit..I cant see the rearend..My gas tank is in the way and the car is backed up too far to get underneath..
    My DSM:
    1992 Mitsubishi Eclipse GSX
    13.300 @ 102.400 MPH
    Loading...
  3. -red97rum-
    -red97rum- Proven Member
    827
    30
    Joined Aug 29, 2002
    Rancho Cucamonga, California
    There's a sticker on the rear end which identifies if it's an auto or manual. I'll take a look at mine when I get home from work.
    Edit: Auto rear diff should have a sticker on it that says J1H. Manuals are B1H or B1G. If you can't read the sticker then I'm not sure what to tell you.. besides taking the cover off and actually counting the teeth on the ring and pinion.
    http://www.dsmtuners.com/forums/dri...-rear-differential-label-number-question.html
    My DSM:
    1992 Eagle Talon TSi AWD
    10.67 @ 126.86 MPH
    Loading...
  4. YoYo_4G63
    182
    3
    Joined Sep 5, 2008
    Sticker is no more. I've heard that for 35 turns of the axle, the driveshaft flange should turn 100times.
    For a 3.54
  5. YoYo_4G63
    182
    3
    Joined Sep 5, 2008
    Anyone knows please? :banghead:
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
