how to get a turbo to spool faster
Posted by Kyromoto, Feb 28, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support STM Tuned
  1. Kyromoto
    Kyromoto Proven Member
    Jan 2, 2008
    179
    Fontana, California
    Ive been looking on the search and cant find anything on there. so im just wondering. besides getting bigger more free flow exhaust or a cold air intake. what else can you do to get your turbo to spool faster. Im fine with the PSI i get just want less lag LOL. o btw I have an evo 3 big 16g turbo on my 92 talon with greddy BOV, apexi exhaust system 3 inch. cut the air box and Maf mod. thank you for any info...
    #1
  2. RallyEclipse98
    RallyEclipse98 Proven Member
    Jul 31, 2007
    549
    15
    Lincoln, Nebraska
    No one complains about the E3's spool. If you have a manual maybe you should shift more.
    .......That or throw some nawszzzz at it.
    #2
  3. TSITurbo95
    TSITurbo95 Proven Member
    Oct 26, 2009
    1,312
    10
    Ohio, Ohio
    EVO3 has great spool time, if you want faster, I suggest going back to a t25 :)
    #3
  4. Jankenshank
    Jankenshank Proven Member
    Oct 23, 2008
    157
    Nashville, Tennessee
    less lag than a e3?
    want to try a supercharger?
    #4
  5. RadDsm
    RadDsm Proven Member
    Apr 28, 2008
    1,226
    21
    Tigard, Oregon
    Check for boost leaks.
    If you have any way to control your timing, you can increase the timing a bit to help spool time.
    #5
  6. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,530
    473
    Greensburg, Pennsylvania
    I've never heard someone with an Evo III 16G and stock cams complain about lag. Are you sure you don't have any boost leaks or pre-turbine exhaust leaks?
    #6
  7. knochgoon24
    knochgoon24 DSM Wiseman
    DSM Profiles:
    3
    Jan 29, 2008
    4,737
    54
    Rochester Hills, Michigan
    You can get adjustable cam gears and mess with the timing of the cams.
    From: How to Tune Cam Gears on a 4g63t - My Pro Street
    #7
  8. Kyromoto
    Jan 2, 2008
    179
    Fontana, California
    I am thinking i might have a boost leak then. and trust me its not the shifting or driving. it spools slow. I had one boost leak directly off the intake side of turbo but i fixed that. Idk where any other ones wud be. I didnt have any leacks on my old stock turbo a couple days ago so i guess it has to be a leak somewhere I dont know about
    wait could it be that i still has stock TB elbow? my friend thinks thats y im getting slow spool. anyone else think that would restrict my spool?
    #8
  9. Gstclipse69
    Gstclipse69 Proven Member
    DSM Profiles:
    Jun 30, 2006
    643
    8
    Columbia, South_Carolina
    A stock throttle body elbow would have nothing to do with it. Boost leak test your intake tract as suggested. You'd be surprised what you will find.
    #9
  10. My1GLaser
    My1GLaser Proven Member
    DSM Profiles:
    Dec 4, 2006
    1,424
    18
    Bartow, Florida
    Your WG flapper is partially hung open.
    Do this.
    1. Make a sharpie mark from the flapper arm to the turbine housing.
    2. Take the small clevis pin out of the flapper arm and pull off the WG actuator arm.
    3. See how much the flapper arm moves until is it fully shut by referencing the sharpie mark.
    I had to shim my WG actuator off the compressor housing with about 1/8-3/16" worth of washers. This was on a brand new MHI Evo 3 16g. It didn't full boost until about 5k right out of the box. It went down to about 3200 after shimming the WG actuator.
    #10
    95ttalontsi likes this.
  11. Kyromoto
    Jan 2, 2008
    179
    Fontana, California
    ok. thanks
    #11
  12. knochgoon24
    DSM Profiles:
    3
    Jan 29, 2008
    4,737
    54
    You may also have an exhaust leak. Just last night I was thinking how my car didn't have as much power as usual. Today I was checking the fluids when I noticed that 2 of the exhaust manifold bolts had backed off. I tightened those back up and all is well again.
    #12
  13. Kyromoto
    Jan 2, 2008
    179
    Fontana, California
    ok ill give that a check as well. thanks
    update. a couple nuts on exhaust mani were lose and one lose on the turbo to exhaust mani. fixed those. feels a little better but still slower then it should be. i dont hit max boost untill like 3500 ish
    #13
  14. FLASH1970
    FLASH1970 Proven Member
    DSM Profiles:
    Aug 22, 2005
    876
    6
    Lake Geneva, Wisconsin
    I'd put the stock turbo back on until you upgrade your fuel system. And get a wideband. And get a way to tune your car. And get a data logging setup. Until you do at least those upgrades there is no point in throwing on a bigger turbo. Your just going to hit fuel cut and run lean.
    But, if you have your heart set on blowing up your engine, you can get the maifold ported, or an FP manifold, cams, head porting. Throwing nitrous might help spool it up too. But full boost at 3500 isn't bad.
    #14
  15. 92_6bolt_1290
    92_6bolt_1290 Proven Member
    DSM Profiles:
    Feb 2, 2010
    118
    Jenison, Michigan
    Are you running your stock exhaust manifold or O2 housing?
    upgrading to the Evo3 manifold and O2 housing help out a good bit to decrease turbo lag, otherwise the idea of an aftermarket FPR probably wouldn't hurt your cause. if you go the route of getting a fuel pressure regulator then make sure you can get one thats rising rate as well as adjustable
    #15
  16. welfle18
    welfle18 Proven Member
    DSM Profiles:
    Sep 14, 2006
    412
    Norwalk, Ohio
    I agree that 3500 full boost is pretty good. I had a 50 trim and got full boost at 3800 (20psi). Do a boost leak test. Mine leaked like crazy from the bov flange and the throttle body gaskets.
    #16
  17. Nati0nalxCrisis
    Nati0nalxCrisis Proven Member
    Nov 18, 2009
    172
    Mukwonago, Wisconsin
    ROFL
    Or you could always try a 14b, spools as soon as you hit the gas. But I wouldn't be too mad about the spool on an E3, the difference between a 14b and E3 would be huge. Your great where you are man.
    #17
  18. donniekak
    donniekak DSM Wiseman
    DSM Profiles:
    Mar 23, 2008
    3,952
    401
    Surprise, Arizona
    If 3500 rpm full boost isn't for you, i suggest a v8.
    #18
  19. ziggo0
    ziggo0 Proven Member
    Oct 13, 2009
    613
    7
    La Porte, Indiana
    There might also be an underlying problem.
    The 2.4L stroker in the SRT4 spools the same sized turbo right around 3000rpm, move to a 2.3L stroker and you should see better spool time. Cams too.
    #19
  20. gstryyder
    gstryyder Proven Member
    Oct 11, 2007
    398
    7
    El Cajon, California
    a relatively easy way would be to get some evo 560's a 2g maf and a wally 190. wideband or logger would do some good and an safc.what type of boost controller are you using? and still... have you checked for boost leaks? are the only mods you have what are listed in your profile? and also what spark plugs you are running? and what type of E3 turbo is it??creating more tension on your wastegate flapper to keep closed longer will have its neg- effects but will help with spool time. if there is a step on your turbine housing of the turbo you can insert a ring... or port it for smooth transitioning. i know it is an oddball question... what clutch n flywheel do you have on your car? is your bov vented? and how much boost are you running?
    #20
  21. 1gDSM4g63
    1gDSM4g63 Proven Member
    DSM Profiles:
    Aug 28, 2007
    1,761
    5
    San Jose, California
    If you think that 3500 rpm is laggy just switch to another, a twin turbo v6, v8, or hell strap a rocket on your car!
    [​IMG]
    #21
  22. chanley talon
    chanley talon Proven Member
    DSM Profiles:
    Nov 10, 2005
    696
    7
    Spencer, Indiana
    I recently installed a water/methanol kit on my car. I have a automatic dsm awd with a knock off evo3 turbo. It seemed to spool slower than the original evo3. However i ran alcohol and methanol and a little water and the spool is ten times faster. I have never drove a car that felt like this. But if you can afford a water/meth kit you will never ever regret it they are GREAT!
    #22
  23. Kyromoto
    Jan 2, 2008
    179
    Fontana, California
    I dont have a MBC on atm. I didnt want higher boost so im leaving it off for the moment. and im checking boost leaks tomorrow as soon as i can build a checker. yes and i just updated my profile those are the current mods atm. im running oem ngks. the turbo is big 16g evo 3 turbo, with double turbine fins. I have standard clutch and flywheel. but the clutch looked relativly new (just bought this car and rebuilt almostEVERYTHING)the BOV is a GReddy and what do you mean vented? it has a nipple on it that you can turn for harder or softer? and i only have stock boost gauge so im not sure how accurate it is atm. but im guessing around 14??? untill i get my new boost gauge i wont really know. but the top end of this turbo as is boosts real hard. just takes a while to kick in as oppose to my gsx with same turbo it spooled like bat outta hell.
    #23
  24. 1gDSM4g63
    DSM Profiles:
    Aug 28, 2007
    1,761
    5
    I don't what you're talking about. Methanol kit does not help better the spool time. It's main purposes is to push out more psi which equals more power.
    #24
  25. wowzers
    wowzers Probationary Member
    DSM Profiles:
    Apr 24, 2009
    27
    Acme, Pennsylvania
    You could try the Cyclone Intake manifold mod...Where theres flappers that are closed at low RPM to help the spool...My buddy on this site untouchablecc i belive his name is has a ebay 16g with this Cyclone Intake mani mod and he sees full spool way before 3500 If im not mistaken Its around 3k for full spool if I remember correctly...If someone who has more experence with this Intake please chime in. Thanks
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
