How to fill ball joints with no grease fitting.
Posted by Scuba_Steve, Apr 29, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support VR Speed Factory
  1. Scuba_Steve
    Scuba_Steve Proven Member
    DSM Profiles:
    May 28, 2009
    113
    Colorado Spring, Colorado
    Do you just fill the boot with grease, then slip it on?
    #1
  2. GRAVEDIGGER
    GRAVEDIGGER Proven Member
    DSM Profiles:
    Nov 26, 2007
    2,683
    89
    Uniontown, Ohio
    I guess you could do that, but normally they are just nongreasable. If they don't have a grease fitting then you can't grease them.
    #2
  3. Scuba_Steve
    DSM Profiles:
    May 28, 2009
    113
    They came with the boot detached. There is no grease at all in them.
    #3
  4. GRAVEDIGGER
    DSM Profiles:
    Nov 26, 2007
    2,683
    89
    Uniontown, Ohio
    I would just put some grease in there and put them together.:thumb:
    #4
  5. pur97tsifwd
    pur97tsifwd Proven Member
    DSM Profiles:
    Jan 31, 2006
    297
    Nevada, Missouri
    they make a fitting that you can put on a grease gun that will slip in the top or bottom of the rubber boot and insert grease on the ball joint you might have to take the nut off. This is after the ball joint is installed.
    #5
  6. ramsack
    ramsack Banned Member
    Dec 27, 2007
    2,196
    14
    West Lawn, Pennsylvania
    Those needles for grease guns are for tiny tiny grease fittings, such as those you find on small heim joints, not injecting grease into a boot. If the joint doesn't have a fitting, you are never going to get grease to go into it. Joints that are meant to be greased have clearance for the grease and channels in the socket to allow grease to flow around it. I'm afraid you are SOL.
    #6
  7. snowborder714
    snowborder714 Moderator
    DSM Profiles:
    Oct 15, 2006
    11,887
    171
    Downingtown, Pennsylvania
    When I installed a new OEM boot on my eBay compression arm a weekend or two ago, I just slathered grease in/around the ball joint and then put the boot on.
    #7
  8. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,562
    508
    Greensburg, Pennsylvania
    I've always drilled, tapped, and installed my own fittings in the non-greaseable tie rod ends on DSMs; never been faced with changing a ball joint on my own yet (dealer replaced the last ones under recall), but they would get drilled and tapped as well.
    #8
  9. bjmauck
    bjmauck Proven Member
    DSM Profiles:
    Feb 20, 2009
    197
    Augusta, Georgia
    I say drill and tap or just use the grease needle.
    #9
  10. 2slow4now
    2slow4now Freelancer
    DSM Profiles:
    Nov 20, 2008
    910
    34
    otwell, Indiana
    Ok I like the drill and tap idea but how do you know you get all the shavings out?
    I have done that with different bearing housings before but the bearings were removable. No chance of contamination. maybe run a vacuum right at the point of drilling and taping but I still don't know.
    #10
  11. cutty2fast
    cutty2fast Proven Member
    May 26, 2010
    173
    ocala, Florida
    thats what i was about to say LOL it dont matter just drill a hole in it and screw in a zerk fitting!
    #11
  12. gieri002
    gieri002 Proven Member
    Feb 25, 2008
    729
    Lake Minnetonka, Minnesota
    yup you just use the needle....
    #12
  13. ricktb
    ricktb Proven Member
    DSM Profiles:
    May 20, 2007
    432
    4
    Edmonton, AB_Canada
    I say drive the thing until the ball joint becomes loose, then replace these whole assembly.. will come pre-lubed and ready to install from the factory. Good to go for another 100K
    #13
  14. Rummy636
    Rummy636 Proven Member
    DSM Profiles:
    Jun 13, 2010
    36
    hartford, Connecticut
    to keep the shavings out, put some thick grease on the drill and tap in the grooves. the shavings will stick to the grease and keep most of the shavings from entering the ball joint.
    #14
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
