How to clean sludge from engine?
Posted by 98EVOECLIPSE, Nov 13, 2012
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support STM Tuned
  1. 98EVOECLIPSE
    98EVOECLIPSE Proven Member
    DSM Profiles:
    Aug 16, 2012
    48
    Rehoboth Beach, Delaware
    I'm in the process of putting in a new head gasket. My old one blew due to the headbolts, and the oil and coolant completely mixed causing my oil and coolant to look like peanut butter.
    Looking for suggestions on how to get this mixture out of the oil lines and block. After install should I just change the oil a few times after running say 300 miles per change until its clean? Any input would be appreciated. Thanks.
    I also plan on flushing the radiator and coolant lines, if anyone has tips on a better method or anything I can put in the coolant to help clean that system too.
    #1
  2. ZombieSix
    ZombieSix Proven Member
    DSM Profiles:
    Jan 29, 2012
    274
    Virginia Beach, Virginia
    Seafoam in oil and seafoam in vacuum lines and seafoam in gas.
    #2
  3. BogusSVO
    BogusSVO Proven Member
    Jul 1, 2009
    5,711
    259
    Pensacola, Florida
    Do you want to do this half way or properly?
    I can tell you a few diffrent ways....
    #3
  4. MJcanada
    MJcanada Proven Member
    DSM Profiles:
    Jun 25, 2011
    2,107
    36
    campabello, South_Carolina
    Take the engine out of the car and take it all to a shop and have it all bead blasted and hot tanked.
    IM EM head & block. It'll all look like new.
    I'd use a chemical flush in the coolant system to get all lines and heater core clean as possible before doing this.
    #4
  5. awdtalon4451
    awdtalon4451 Proven Member
    Aug 23, 2007
    387
    Ocean springs, Mississippi
    Im listening...:D
    #5
  6. 98EVOECLIPSE
    DSM Profiles:
    Aug 16, 2012
    48
    I was considering seafoam, didn't know you could put in in gas
    Tell me both then I'll decide LOL
    I know this is the best and most efficient option, just don't have the money for that. Looking for a way while it's still in the car. Anything I need to do before the head is installed?
    #6
  7. BogusSVO
    Jul 1, 2009
    5,711
    259
    Pensacola, Florida
    OK... This will make a huge mess.
    With the shortblock in the car....
    Pull the oil pump and front case, leave head off, Rods/pistons, crank in block
    1 gallon of diesel fuel/kerosean, assortment of brushes, and a good gasket scraper.
    Make one brush an old tooth brush, and a parts washer brush.
    Stop by a gun shop, grab to rifle nylon or copper brushes on long handles 20ga and a .22/.25 cal
    1qt purple soap
    2 cans brake clean
    1 can WD40
    1QT oil
    1 Roll blue paper towels
    Wine bottle cork
    Water hose
    Air compressor w/ hose and blower nozzle
    Read these links
    http://www.dsmtuners.com/forums/new...r-how-clean-block-deck-pistons-installed.html
    http://www.dsmtuners.com/forums/cylinder-head-short-block/362154-how-final-wash-engine-block.html
    Remove all the old gaskets
    Scrub the inside the block around the crank, use brushes & diesel fuel
    Run the 20ga brush down the main oil galley
    Use the .22/.25 cal in the vert oil passage to the head
    You can also scrub the outside of the block with this
    Now hose everything down, inside and outside the block, crank rods everything! Flush the oil galleys with water till they run clear.
    Now with purple soap spray it all down and scrub some more. This will also remove all the residual oil film left from the diesel fuel.
    Rotate engine as needed to get under the pistons.
    Blow dry the cylinder bores and the HG surface, get some WD40 or a wipe of motor oil on the bores to prevent rust.
    Now touch up clean any small dirty/oily spots with the brake clean
    Spray WD40 on the inside the block crank area to help prevent rust.
    Now flush the vert oil galley with brake clean, and blow out with compressed air.. it will come out where the front case mounts.
    Now take the wine bottle cork, and wittle it down so it fits very snug into the main oil galley on the front of the block, if it has a slight leak, it will be ok.
    With all the cleaner, solvents and water that has been run thu the oil galleys, some has made it between the crank bearings, both main and rods, this all has to be displaced to prevent rust there.
    Now pour oil down the vert oil passage that feeds the head, a small funnel, or the nipple top from a gear oil bottle will be handy at this point.
    A buddy to help would be great at this point, or Mom, Dad, little sister.....
    Start "Burping" the air nozzle down the vert oil passage, this will help push the oil on to the bearing surfaces, be carefull not to blow the cork out of the front of the engine.
    As you do this, have the helper slowly spin the crank over, untill you see the oil drip from between the side of the con rod and crank. and come out of the oil squirters if your engine has them.
    You will have to stop and refill the oil galleys as needed, 3 or so times.
    Once you start, you can not stop and let sit, rust will start to form on the crank bearing surfaces
    So no letting it sit over night till you force a good amount of oil over the bearing surfaces!
    Now if you have the short block out of the car, you will follow most all the above, with a few changes.
    You will remove the rear oil galley plug in the back of the block.
    Insted of Diesel fuel, get a can of Easy-off oven cleaner (yellow can) or Easy off BBQ cleaner (black can)
    Have acess to a pressure washer is best ( Car wash)
    Welcome to the "shade tree" way of cleaning a short block......
    #7
    delta448 likes this.
  8. 98EVOECLIPSE
    DSM Profiles:
    Aug 16, 2012
    48
    Holy bajesus how long does that take?!?! Lol
    #8
  9. jmartinez1228
    jmartinez1228 Proven Member
    Feb 20, 2004
    330
    Rocky HIll, Connecticut
    Bogusv quick question. When my wife goes to get her oil changed all the shops are always pushing an "engine treatment" they say it's to remove all the old oil and sludge in an engine. I did it once just to see what it is. They drained all the oil and filled it up with a jug of this so called "conditioner", let it run for about 5 minutes. Flushed it and put in fresh oil. It was about the price of two oil changes and I never noticed a difference. Any idea what it is they are using and if it's even worth it?
    #9
  10. Nate355RS
    Nate355RS Proven Member
    DSM Profiles:
    3
    Oct 25, 2012
    338
    44
    Salem, Virginia
    Yep, fill the tank up to the top then pour in a whole bottle. And then run that tank until it's on fumes. It's great for cleaning out injectors.
    I would be careful putting Seafoam in the oil. If you do that don't run it for more than a couple hundred miles tops. The reason being is that it cleans your crankcase by loosening sludge and build up. Then all that sludge and buildup is now free in your oil and traveling throughout your engine. When you change your oil after Seafoam it will be blacker than Satan's heart.
    For the top half of the engine, MCCC is a MUCH MUCH better solution than Seafoam. You can get MCCC (Mopar Combustion Chamber Cleaner) from a number of auto parts stores or any Chrysler dealer.
    MCCC actual expands and foams as it heats so it will clean better and reach more places than Seafoam will.
    #10
  11. foxracing4500
    foxracing4500 Proven Member
    DSM Profiles:
    Jan 21, 2012
    287
    9
    State College, Pennsylvania
    removing sludge isn't fun, glade I didn't suffer like my audi brothers, yet I still run seafoam for 10 miles before an oil change just in case.
    pic is of an audi 1.8 turbo, audi never stated NOT to use non-synthetic oil. The results? this.
    [​IMG]
    #11
  12. red_devil
    red_devil Proven Member
    DSM Profiles:
    Jul 13, 2005
    903
    17
    Cape Coral, Florida
    That looks like something from the Walking Dead.
    #12
  13. ExtremeTurboSystems
    ExtremeTurboSystems Supporting Vendor
    Jul 30, 2012
    190
    5
    Vancouver, Washington
    That is impressive...Looks like mud.
    #13
  14. KAOI
    KAOI Proven Member
    Aug 1, 2011
    82
    Wheaton, Illinois
    Man... Ive heard of engines taking a sh** but this is out of hand
    #14
  15. BogusSVO
    Jul 1, 2009
    5,711
    259
    Pensacola, Florida
    That depends on you.
    My Close buds and I have a saying when it comes to working on our cars..
    "Be as anal as you want to be!"
    With having the head off, from pulling the oil pan and front case, all the cleaning to the finish of getting the oil on the bearings... I would say 3-5 hours... longer if everything ir really nasty.
    I really do not like the oil flush, or engine treatments.
    The chemical additives will keep breaking down the sluge, even tho they removed the bulk of it.
    Its one thing if you just have a light oil varinish in the engine, but if you have a moderate to heavy gunk sludge build up, the high detergent can and will break down the heavy gunk then it flows to the oil pan, the thinner stuff will clog the oil filter, and the thicker heavier stuff will stay in the oil pan, and can clog the oil pick up.
    Most oil filters have a bypass built into them so if the filter gets clogged, it goes into bypass and lets unflitered oil circulate thu the engine.
    If the oil pick up screen cloggs, well thats simple, the engine starves for oil.
    Neither case is good.
    If you keep up with oil changes, there is no need for a flush or treatment.
    Also some treatments come with a seal conditioner, well this softens and swells seals like the rear main, cam seals and valve stems seals, now if these seals get subjected to that, they can and will over swell and rip apart, and can cause an oil leak.
    #15
  16. funcar
    funcar Proven Member
    Oct 18, 2007
    34
    Bethel, Ohio
    Its all up to you and when you wanna work on the engine again. Even with a budget a proper cleaning is needed.
    #16
  17. 98EVOECLIPSE
    DSM Profiles:
    Aug 16, 2012
    48
    Lots of helpful info and suggestions thanks everyone for pitching in. As soon as I noticed oil in the coolant I immediately stopped driving the car. It wasn't long enough to build up or do damage, so I feel that seafoam and a couple oil changes might do the trick. I have a limited amount of time while working 2 jobs to fix it, very little experience, and literally no cash at the moment.
    Like I said, the car was BARELY driven after it blew, so here's my plan.
    Use a razor to clean the top of the block, brake cleaner to remove any residue, and the seafoam and oil changes. I will flush the coolant system until its clean as well. Hopefully that'll do.
    #17
  18. MJcanada
    DSM Profiles:
    Jun 25, 2011
    2,107
    36
    I've seen a 350 engine full of oil coolant milk. The intake valley under the IM completely full up. Inches thick. Same with valve covers. Idk how it was getting oil anywhere.
    #18
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
