Spoolin4Ever
- 1,142
- 13
- Apr 24, 2005
Moses Lake,
Washington
6 bolt 1gb
When I am setting the tensioner pulley, with a new belt, a new tensioner the pin is still in.
I start with the 2 holes at about 7 and 11 (upreight) with the center bolt barelt hand tight. I put the special tool on (connected to an inch lbs torque wrench).
Turn the pulley clockwise, and tighten the center bolt, about where it allows the pin to slide in and out. Perhaps it is off a bit, so I then turn it more with the special tool (without loosening it again). Is that ok, or is it too loose?
In other words, is it ok if you can still move the pulley with the special tool after tightening, is it too loose? Is it ok to adjust it after tightening and retighten or always must start over?
Seems like I had it about right, but I could still move it, and if I torqued it to actual 35 lbs, it would mess it up.
Would it make it come loose or slip a tooth?
PS I know the spec is 35 lbs but hard to get torque wrench in there...as you know.
