How hot does your engine get???
Posted by shallowshowcase, Sep 18, 2005
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
  1. shallowshowcase
    shallowshowcase Awaiting Email Verification
    Jun 29, 2005
    148
    Arab, Alabama
    This being my first turbo car, it just stood out at me. But i bought a car that was hiding alot of problems (broken harmonic balancer, oil coming out of valve cover, fuel pump not mounted with the bolts, alot of stripped bolts)
    after fixing what seems to be alot of the problems, ive always noticed how hot the car gets. my friends love it and ill drive down the road and back and we will throw ice on the exhaust manifold and watch it skip liquid and goto steam... this dont require much driving, either.. but its like after i get home from work i cant work on my car for HOURS or maybe even the next day.. well my question is
    how hot is too hot???
    #1
  2. hereitcomes
    hereitcomes Awaiting Email Verification
    Apr 9, 2005
    866
    16
    Wauwatosa, Wisconsin
    there are alot more parts working in turbo cars, and a lot more fluids/air flowing. It doesnt take much for the motor to get hot quite quicky.
    My GSX usually heats up pretty good in about 10 blocks with not even getting on it.
    Even though its a different motor....my buddys B18C1 gets so hot after starting it and revving it a couple times that you have to let it sit for about 30 min.
    hope this helps some bro. good luck.
    #2
    talondude4 likes this.
  3. talondude4
    talondude4 Proven Member
    DSM Profiles:
    Mar 9, 2005
    387
    13
    Plymouth, Maine
    OK well buddy your manifold gets hot(duh), :rolleyes: But how is the engine temp? Another thing is you can put you finger on the manifold and see if its really hot!!(kidding don't do that).
    The turbo will heat that manifold fast, All I have to do is start mine and its hot.
    #3
  4. 95-DSM-RS
    95-DSM-RS Proven Member
    Sep 16, 2005
    51
    Henderson, Tennessee
    My car does the same thing i was beginning to wonder is the coolant parts were gone out. I can actually cook a steak on my engine. :dsm:
    #4
  5. 90TSIwhite
    90TSIwhite Probationary Member
    Jul 14, 2005
    18
    Lincoln, Nebraska
    Since the Turbo is under your hood, your goign to see some higher temps, and Stock thermostats dump at 190, You may concider a lower Temperature Thermostat if High Temps worry you. My 1g has a 160 and It averages a temp of around 185.
    #5
    hereitcomes likes this.
  6. 95-DSM-RS
    Sep 16, 2005
    51
    Is the low temp t-stat something i can go to autozone and get? I always work on my car after coming back from a drive to set stuff differently and i cant keep getting water blisters in my palm...LOL
    #6
  7. tc1155
    tc1155 Probationary Member
    Sep 15, 2005
    28
    kenmore, New_York
    i gotta low temp from autozone i belive its a 160
    #7
  8. 95-DSM-RS
    Sep 16, 2005
    51
    do you remember about how much it costs? I am lookin to get one also...I cant take the burns much longer I have no finger prints now.
    #8
  9. DSMvroom
    DSMvroom Proven Member
    DSM Profiles:
    Aug 8, 2004
    519
    3
    Issaquah, Washington
    dunno how hot the engine gets, but my valvecover is definitely hot enough to flake 500 degree paint off of it because that's what it is doing to my once-cool anodized red paint.
    as far as the "thermostat" mod, you all better do some searching. I've come across some discussions about it in the past. I don't remember what the outcome is, but it may be worth your while.
    #9
  10. 95-DSM-RS
    Sep 16, 2005
    51
    and see thats funny because the guy i got my car from spray painted the valve cover gold and i cant get that off to save my life. It gets so hot but that spray paint won't peel...
    #10
  11. 90TSIwhite
    Jul 14, 2005
    18
    Lincoln, Nebraska
    Mine was 20 bucks from a store locally here in Lincoln.
    Good luck fellas! :thumb:
    #11
  12. 95-DSM-RS
    Sep 16, 2005
    51
    Ok thanks man im gonna look in to getting me one of those. :dsm:
    #12
  13. 94Jettameowpsst
    94Jettameowpsst Proven Member
    DSM Profiles:
    Dec 30, 2004
    780
    4
    Pittsburgh, Pennsylvania
    The general concensus in most all cars is running a lower temp thermostat usually wears out your water pump quicker. And being that it takes so much time to change a wp in our cars, id probably just get another stocker. Then again this is coming from someone that has yet to put his thermostat back in :notgood: , i usually have a max cruising temp of about 169+/- a few degrees.
    #13
  14. talondude4
    DSM Profiles:
    Mar 9, 2005
    387
    13
    Plymouth, Maine
    cough cough bull sh*t, ummm no it don't man. ROFL
    OK tell me this how is a thermostat harder on a water pump, its after it so whats the deal with changing it. ROFL
    #14
  15. GSX6bolt
    GSX6bolt Proven Member
    Sep 14, 2005
    130
    3
    Bethlehem, Pennsylvania
    my coolent hose was leaking and i can tell you from experience, like some have said already, these cars get hot almost immedietly. be careful not to crack your block.
    #15
  16. gridlyne
    gridlyne Proven Member
    Aug 15, 2005
    186
    7
    Queens - Woodsi, New_York
    These cars, especially the first gen are known to run hotter.
    #16
  17. azkikr10
    azkikr10 Proven Member
    Jan 12, 2003
    280
    Union City, California
    Aint that the truth. I can't get my coolant temps below 213 to save my life
    #17
  18. kicknurass4fun
    kicknurass4fun Proven Member
    Sep 5, 2005
    135
    5
    Fox Lake, Illinois
    Ya my car ran at around 203 till i put a fmic on it. Now it sits at like 210-213. I put a slim line fan on while still using the stocker and that helped quite a bit.
    #18
  19. Vallary99
    Vallary99 Guest
    My EGTs are usually between 1000 and 1400 degress. Alot depends on how long I've been driving. My car gets up to operating temperature really fast and it takes like half a day for it to cool off enough to work on it. That's the disadvantage to cast iron.
    #19
  20. dr1665
    dr1665 DSM N/T Wiseman
    Jan 6, 2003
    1,380
    41
    Phoenix, Arizona
    If something is general consenus, that would mean most people have heard about this concept. Using a lower tStat has no bearing on water pump longetivity as far as I know. The pump is belt driven. What does the tStat have to do with water pump longetivity? If you're right, you need to explain why.
    Using a lower temp tStat is a common modification on these cars. I've never, in almost a decade of owning a DSM, heard anyone say you shouldn't use a lower temp thermostat.
    #20
  21. Thomas91169
    Thomas91169 Proven Member
    DSM Profiles:
    Jan 18, 2004
    1,344
    25
    modesto, California
    dsmlink showed me that with the fmic i was running around 225*. i flushed the system, new coolant(50/50 premix), can of water wetter, 180* tstat, and new cap, and temps went down to 210ish. then with the fmic off, i was seeing only 190*.
    and thermostats have NO effect on the longevity of a water pump. thermostat or not, the pump still pumps the same amount of fluid. you could have a 190 or a 170 and it will make no difference on the amount of water the pump flows. driving agressively and lots of redlines will wear out the bearings quicker.
    #21
  22. Zenja
    Zenja Proven Member
    Nov 16, 2003
    217
    Saskatoon, Saskatchewan_Canada
    I've heard that a hotter engine runs more efficiently, but that could be wrong.
    My valve cover doesn't get that hot. I can put my hand on it for a little bit. The exhaust manifold on the other hand gets really hot. I find that it usually takes a while for the car to warm up while driving, but if I just drive a little bit and shut it off, the temps will continue to rise. That exhaust manifold gets hot and spreads the heat to the rest of the engine. When I need my car to cool quick so I can work on it, I cool the exhaust manifold with water until it stops steaming (I don't mean just dump a bucket on it, that could crack it) and that helps the car cool down quite a bit. That's just a little tip.
    #22
  23. 95dsmracer95
    95dsmracer95 Proven Member
    Feb 14, 2005
    35
    Azle, Texas
    wow my engine (Non-Turbo) used to get up to about 220 F. in summer and about 200F winter. It usually takes my engine (idling) about 20-30 minutes to get too hot to touch!
    #23
  24. 94Jettameowpsst
    DSM Profiles:
    Dec 30, 2004
    780
    4
    http://dsmtuner.com/forums/showthread.php?p=1632876#post1632876
    Post number 5. This isnt the only time i have been given such authority when it comes to running w/out a thermostat or having a low temp thermostat. I personally dont understand how it could be that bad but if you think about it, it would actually make the waterpump work overtime. Im sorry if i spread misinformation, not just in this post, but thats just what i've been told. Now the car i have now i took the thermostat out to rule out a few problems and have yet to put it back in. Now, maybe its just irony, but one of my belts (which are all new) are seizing up on the middle pulley....the water pump, and its squealing. So...idk ill stick with the stock temp thermostat.
    #24
  25. talondude4
    DSM Profiles:
    Mar 9, 2005
    387
    13
    Plymouth, Maine
    Your water pump runs off your belts so therefore it doesn't spin or rotate any faster the the belts make it.
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
