rough
- 800
- 74
- Nov 12, 2012
Indianapolis,
Indiana
Installed the 1G BOV, Sounds great! This is how it will sound with the stock intake pipe.
Please note, once you modify or upgrade your intake pipe, you lose this sound. This is how it sounds before cutting this BOV re circulation pipe.
This unique sound is really caused from the re circulation tube that narrows at the end of the tube that's protruding in your intake pipe.
Another View
and one more from the other side, this tube is huge and blocked at least 30-40% of the flow!
And here is it removed, I used a dremel, it's not perfect, as I've upgraded to a Injen. Did this to see what kind of gains my butt feels, and to see how it affects the BOV"S sound.
Here is my finished results, I sanded all around and inside and outsde the edges to make sure no plastic pieces would come off and get sucked into the turbo.
Once installed, I felt a pretty good gain by the butt o meter feeling, but the sound... is just awful! Just like a quick gush of pressurized air with a lot of volume! NOOO I loved the sound before the mod!! But the but feeling noticed a gain, and now my turbo spools faster, gets to 15+ PSI quick, and doesn't fall on it's face as bad up top!
Will post video of this modification in action. I would have the video already, but it's raining out and I can't build boost without the spinning tire sound drowning the blow off sound.
Another View
