Demon33
- 296
- 2
- Aug 11, 2008
Southern,
California
I have a 1G GSX and I'm trying to rule out some causes of the clutch not disengaging. I just rebuilt the master cylinder and flushed and bled the line. The slave was rebuilt about 10 months ago and it's not leaking. I replaced the rubber hose with a braided hose. The clutch and flywheel were replaced about 8 months about and I used a new OEM throwout bearing and pivot ball. I still have to check the clutch pedal assembly for wear, but I currently have the master cylinder rod almost fully out, while still allowing the slave to return to its compressed position when the clutch pedal is released and I still can't get the clutch to fully disengage.
Can someone tell me what to look for externally (without having to drop the transmission) to diagnose a bent clutch fork? My logic says that if the fork is bent, the end of the fork at the slave cylinder should sit closer to the passenger side, as that is the direction of the force applied by the slave cylinder. Currently, mine sits closer to the driver's side, so I'm thinking my fork is still good.
If it's still good, I'm going to pull the clutch pedal assembly and have a look at it for wear.
Thanks for any and all help.
