Tiki2777
- 1,022
- 87
- Oct 9, 2011
Omaha,
Nebraska
Just straightup tell me how .
Note: This feature currently requires accessing the site using the built-in Safari browser.
1- On cruise control cars, unless you have small arms/hands, you will need to loosen the cruise control modulator and move it out of the way. The CC Mod (might not be the correct term, I will look in up and edit this if it's not) is a round, silver looking thing that is about 3 inches in diameter. It is located roughly just above the alternator. It has a cable coming out of the top of it that is routed to the induction system. There are two 10 mm nuts that hold the modulator to the mounting bracket, and two 10 mm nuts that hold the mounting bracket to the frame. Remove all 4 nuts and relocate everything so that you can access the top alternator mounting nut. I use a tie wrap to hold everything out of the way.
2- You should now be able to see the top alternator mounting nut. It is a 15 mm nut and can be difficult to get on unless you have a longer wrench. Find whatever tool you have and loosen it.
3- On some cars you would pry on the alternator until the belt is tight, then re-tighten the mounting nut or bolt. The system on my car utilizes an adjustment bolt. This bolt is located at the back of the alternator mounting bracket. It is difficult to see, the head points right at the firewall. It has a 12 mm head and to remove slack you turn the bolt as you would to tighten any normal bolt. It can be a turd to get on and turn. I finally got a very small 1/4 inch drive socket/ratchet on it. You really have to cram your arm down in there and pretty much work by feel.
4- Do not over-tighten your belt. If you do you will cause accelerated wear on your belt and/or bearing failure on your alternator. Adjust a bit, check the belt tension, adjust more if needed, repeat. You want the belt to be reasonably tight, but not so tight you cannot deflect the belt with moderate pressure with a screw driver.
5- After you have your belt to the proper tension tighten the top alternator mounting nut.
6- Now back the alternator adjustment screw off about 1/4 of a turn. This helps reduce the binding force in the alternator mount and helps preserve the adjustment screw.
7- Replace the Cruise Control Modulator if present. Watch out, it is easy to drop those 10 mm nuts down into never-never land.
8- Re-attatch the negative battery cable and you should be able to start it up and see if the squeal is gone.
Its not that god for saking hard USE COMMON SENSE.
