How do I tell if my frame is bent
Posted by NetJoker187, Jun 20, 2010
Please Support ExtremePSI
  1. NetJoker187
    NetJoker187 Probationary Member
    9
    Joined Mar 27, 2006
    Brownsburg, Indiana
    well last night I hit someone in the ass and now I need to know is there anyway I can tell buy just looking under the car and hood if the frame is bent ?
    [​IMG]
    Log in/Register to remove ads
    My DSM:
    1992 Eagle Talon TSi AWD
    13.813 @ 101.110 MPH
    Loading...
  2. SupremeDsm
    SupremeDsm Proven Member
    550
    3
    Joined Aug 13, 2008
    Indianapolis, Indiana
    Yes there is but you need to take the headlights, hood, and front bumper off. If it is bent you will notice that it goes to one side more than the other.
  3. dented_coffee
    dented_coffee Proven Member
    510
    12
    Joined May 14, 2009
    West Branch, Michigan
    you cant because the frame is slightly curved in the front unless you knotice some really messed up parts. under the fender there is a dimpled sheet of structual metal that in front colisions causes it to fold. if i still had my 1g i would go out and use a tape measure to measure the frame distances for you. i can still go to a friends house and use his 93 thow if you want me to. it no problem.
    the frame on the 1gs are dam tuff in the front IMOA. how fast were you going when you hit or how fast did you car mae contact. it looks like its mostly on top near the hood. i say its ok. you dont have to worry about the alignment because the controll arms are attached to the subframe and isnt as voneralbe even with a bent front frame.
  4. SupremeDsm
    550
    3
    Joined Aug 13, 2008
    Well those zones are called crush zones just to clear all that up. And yes can tell if a frame is bent just by looking at it. I work in a body shop at a dealership where I live so I know these things. Frame could also be bent up or down. The only true way to tell though is to use a tram guage on 4 mounting areas within the dog house such as headlight mounting positions and hood hinge mounting positions or by using a measuring system. You can try to replicate a tram guage by using a piece of string measure 4 points with the bolts still in them and put the string in the middle of the bolt on the head. Take it across to see how long it is. Then compare it to the other side. This will tell you if your dog house is square or not!
  5. NetJoker187
    9
    Joined Mar 27, 2006
    Brownsburg, Indiana
    I was going 30 or so by the time I hit the van I have to go get a towrope and get this bad boy back home then i guess i will take a look under the hood and see what i am working with. I know there was some oil on the ground so that is never a good thing.
    Both these are bent and twisted bad along with everything pushed back about 4inc's so I take it the frame is bent ?[​IMG]
    My DSM:
    Loading...
  6. dented_coffee
    510
    12
    Joined May 14, 2009
    you could of gotten lucky like sum due and had the damage swept up and just got everything else in the front. the oil might be from the oil cooler if you have one or the filter area.
  7. NetJoker187
    9
    Joined Mar 27, 2006
    Brownsburg, Indiana
    I found out the leak was coming from the radiator It is busted and pushed back all the way back to the j pipe. If the frame is not bent I wonder oh bad it is going to be trying to fix this thing never done any body work before guess it is time to learn or sell the thing. [​IMG]
    My DSM:
    Loading...
  8. dented_coffee
    510
    12
    Joined May 14, 2009
    if you can get a welder and practice on some thin metal you will be fine. all it really is is alot of pinch welds that you have to drill out. make shure u use a seam sealer of some sort when re welding the new shell parts in place. it will eventually rust from the inside out. most of the 2g rusted shock tower problems are because of that.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
