Please Support STM Tuned
Please Support ExtremePSI
2G How do I adjust my master cylinder rod
rolltidero
319
24
Jan 9, 2014
Madison, Alabama
I know this has been beaten to death but I am experiencing some issues adjusting my master cylinder. I am experiencing the 2G pump up in the clutch. I had my clutch replaced last summer and the master and slave cylinders replaced about 2 weeks ago. I went out of town so I didn't get to drive the car around so I'm just now finding the pump up. The issue I'm running into is I turn the nut on the rod and it just turns and turns but doesn't move. Also the top of my pedal doesn't look like the pictures I've seen. Below is a picture of where the rod connects to the pedal. Any help would be greatly appreciated.
Follow the video. From the sound of your post you are not spinning the actual rod. You need to grab the part of the rod that has no threads with a pair of pliers and rotate it clockwise (If you are underneath the dash looking at it upside down) into the clutch pedal assembly.
There has been some revisions of the piece that attaches to the pedal, not all of the OEM clutch masters look the same.
I've seen the jacks video. Is the nut I have to break loose the one on the front of the silver thing? If so, that not won't move. I turn it and turn it and it doesn't move on the threads. I can't see anything else turning that I'd have to hold in place while I turn to break it loose.
Ok so I need to turn the actual rod. Is the locking but I need to break loose the one on the front of the silver thing?
You need to loosen the jam nut that sits between the pedal end and the master itself. You want the nut to move away from the pedal, so it's not preventing the rod from moving in or out.
If you're turning it the right way and it's not moving toward the firewall, then it's probably stripped.
Turning the rod is the adjustment the jam nut simply locks it in place.
Just an update on this thread, I am trying to loosen the nut on the rod but the rod turns with the nut. I can turn it either way clockwise or counter clockwise and it doesn't affect my pedal at all. I can't seem to get anything with enough grip to hold the rod while I turn the nut either. Any ideas?
Use a vise grip pliers to hold the rod so that it doesn't turn as you break loose the locking nut with a wrench.
I disagree. Nut should break loose. What's holding it is the clevis, not the rod. To adjust the rod you do not need pliers or vice grips. Wiggle the pedal with one hand and adjust the rod with the other. Takes some work to get Into this position but its doable and the rod will turn easily both 1g and 2g.
Another update, hit it with some PB Blaster and that didn't do anything or so I thought. I tried turning the nut and again the rod turned with the nut. Started driving a short way to get some food and randomly my clutch went extremely soft, not undrivably soft but no longer experiencing the pump up. I immediately pull over and check my fluid thinking I popped a gasket or something from all the excess pressure and my reservoir fluid was still full. So I went into the cabin and checked the MC rod and the nut had backed itself off and I could turn the rod with a pair of pliers. I'm gonna keep an eye on it to make sure it stays adjusted but for now it's adjusted somewhat correctly (it's not pumping up). Thanks for all the quick responses everyone.
Just because its not pumping up does not mean that it is adjusted correctly. Follow the video and do it correctly before you start another thread titled "Clutch slipping" or "Transmission shifting notchy"
That's why I said "somewhat correctly." I plan to monitor it and adjust it as needed until I can get it to the right point described in the Jack's video.
I personally like this video more for clutch adjustment. I think he does a better job showing what needs to be done.
The Jack's video is ok, but to me, it's not enough.
If you do it by the video you should only have to adjust it once.
Not always true. I followed the Jack's video the first time I tried and got so frustrated by it, that I drove around for months with poor clutch engagement until I found this other video.
