Please Support Kiggly Racing
Please Support Rix Racing
2G How can i tell what Hoslet turbo i have HX35 or Hx40
Twizted99GSX
140
5
Oct 12, 2014
Champaign, Illinois
im trying to find a Turbine Housing and there is one for Hx35 and 40 and I don't know exactly what I have on here...Its a BullsEye Housing and one is for each but look exactly like each other so is it the size of hole the CHRA fits in or the Opposite side or what? I looked around before posting this so if there is one I didn't find it.. thanks..
it doesn't ask me for measurements on xtreme just says external waste gate on O2 sensor or on manifold and that's it... doesn't ask for measurements.. says its a .55 A/R and same verbiage for each description of each.. so I cant tell apart the difference.. and there is one for hx40 and hx35 just don't want to purchase one and it not fit exactly
What turbo do you have? If you have a hx35 then get it for the hx35. hx40, get it for the hx40.
Then decide if you want the wastegate on the o2 housing or the manifold. If you choose the manifold, the o2 housing won't have a hole where the wastegate hole normally is.
Basically the 40 has a bigger hole for the larger turbine compared to the 35. But from internet pics they will look basically the same but they are machined to fit the specific turbine specs of either the hx35 or the hx40.
The difference is the size of the turbine housing itself, I actually ended up buying an HX35 with a BEP housing and having the guy ship it directly to Justin @JusMX141
Turned out the guy had put an hx40 hotside and attached it to an hx35.. which is like hooking up an 8cm housing off an fp red to a 14b. will it go together? absolutely. is it gonna work? Not so great. Take measurements.. Justin should be able to give you some ideas or just google the specs of the turbine
I’m not even sure how you can be confused here.... did you even look? It says what turbo it’s for. You just have to google it.
Hx35 .70 T3
https://www.extremepsi.com/store/product.php?productid=23483
Hx40 .70 T3
https://www.extremepsi.com/store/product.php?productid=23484
Hx35 .55 Td05
https://www.extremepsi.com/store/product.php?productid=23481
Hx40 .55 Td05
https://www.extremepsi.com/store/product.php?productid=23482
Or are you saying you have the turbo and hot side, but your not sure it’s the correct hot side?
Yes I already have the turbo just not sure its the correct hot side.. and I did google it... and the bottom 2 are what im looking for just wondering what is the difference from the 35 to 40.. I am pretty sure its a 35 just was checking on how to make sure cause im tired of ordering stuff that doesn't fit and returning it for a different piece... so just checking and double checking before I order... Previous owner did a lot of WONKY stuff I am NOW correcting...
Thanks for that.. that's what im trying to find out if it was modified like yours was.. so I am trying to see if the hot side is a hx35 or 40... when I put it in the previous BEP housing it was a bear to get in.. had to knock with rubber mallet so I was wondering or was it just a tight fit to begin with.. Its hard to clock once its set in.. even with bolts loosened..
Again I am NEW NOT A PROFESSIONAL.. So I am trying to learn... I appreciate any info.. But also have limited time to research for hours on certain things.. SO I DO appreciate any info given that helps HOURS of digging for info..
Youll have to measure the turbine wheel of your turbo, and measure the hole it fits into the housing. Post them up. I’m sure @JusMX141 can tell you if the clearance is correct. There ahould be very very little space between the housing and turbine blades.
You never said if you had an hx35 or 40 by the way.
And if you had an hx40 with an hx35 housing I doubt it would even bolt on.
yes it is a hx35 says on the plate on the cover but was just making sure there wasn't a swap on anything. so I could check n make sure before ordering parts id have to return. plus own personal knowing of the turbo.
and yes the BEP its what im looking for.
I think everyone is confused of the question here.... From what I am reading he is asking if he has an HX35 or HX40. He doesn't know what turbo he has. Am I wrong? if the face plate on the turbine housing says HX35, then that is what you have.
the only reason I asked this question at all was because when putting the BEP back on my turbo I have it wouldn't just slide in and done.. it had to be hit with a rubbermallet to get it to seat.. and then you cant clock it if its pushed in because its soo tight it cant turn with out hitting with a mallet to clock it.. so I was wondering if it was different in any way as to why its such a bear to clock or even set it all the way in housing... and if I order a new BEP I wanna make sure I order right so its not a bear and it spins a bit easier than this last one...
and again new to ALL this sorry my question confused people.. trying to learn as I go..
Is it or your turbine chra rusty? And when you fit It on did thr blades spin freely?
