dacowgod
Supporting Vendor
- 447
- 211
- Feb 3, 2006
Morgantown,
West_Virginia
This list is the tip of the iceberg... I have pulled in at least 10 cars that I haven't listed any parts from as I've been VERY busy setting up the new shop and dyno area and catching on customer work...
At any rate.. Black Friday is around the corner so I wanted to at least get some of the more interesting items listed up!
There are literally several thousand other parts that are here that are not listed.. if you need something Stock or not feel free to ask...
All parts located in Morgantown WV
call or txt 304-813-2405 - Ricky
EVO 3 Intake Manifold - $200
1g JMFab SMIM - $375
MHI Big 16g - $425
Billet 16g - $500
MHI TDO5h 20g - $500
FP 68hta gen1 (The good one ;-))- $625
Cleaned and flowtested ID 725 Hi-Z Injectors - $350
Cleaned and flowtested PTE 1000cc injectors - $275
Cleaned and flowtested PTE 550s - $125
Cleaned and flowtested FIC ASNU 1050cc injectors - $400
2g Skunk2 coilovers w/ Tokiko Blue struts - $450
Brand new 2g/evo Oliver Billet "Ultralight" Rods - $725
Used DNP Style exhaust manifold (DSM Flanged) - $50
Chinese 16g in good shape - $75
Kiggly 7 bolt flexplate - $100
2g black box ECU - $75
slightly Used Gates racing Kevlar belt - $50
Fuel lab "Prodigy" inline fuel pump - $300
Brand new Tial MVR 44mm wastegate (Box is unopened) $330
BBK 62mm DSM Throttle body - $150
PTE 6766 - Freshly rebuilt 0 miles
.81 Open T4
3" Vband out
H Cover w/ 4" inlet and 3" outlet
Rebuilt by Justin Whitesell (Did not need a rebuilt just a courtesy before resell to be cleaned inspected and consumables replaced)
$875
Brand new HX40
Built by Justin Whitesell as well
6 blade 60mm Pro compressor
Large 76/67mm Turbine
BEP .70 AR T3 exhaust housing (Machined to accept the 76/67 Turbine)
T3
3" vband out
$875
Freshly built 2g 7 bolt short block(bottom end)
Eagle/Wiseco/ACL - 0 miles - $1800
Accufab 75mm Throttle body (Mustang flange) - $150
FP Exhaust manifold - $175
3g Lifters - $65
Genuine Greddy type "RS" Bov - $75
ARP 6 bolt head studs - $50
ARP 7 bolt head studs - $65
Walbro 255 pump (2g) - $40
Aeromotive AFPR w/ gauge - $125
Fuellab AFPR w/ gauge - $125
ECMLink V3 Full for 2g w/ ecu - $575
ECMLink V3 Full 1g w/ 90 ECU - $575
Innovative LC1 wideband w/ gauge & Sensor - $125
Brian Crower 272 Cams - $325
63mm Non turbo Throttle body - $125
1g Shep Stage 3 transmission w/ welded center diff - $2000
Competition Stage 3 clutch (Very low miles) $275
ACT 2900 Clutch w/ street disc (Also very low mileage) - $275
4 bolt manual rear end w/ axles and cups - $400
2g GST Transmission - no grinds - $350
MHI Big 16g - $425
Billet 16g - $500
.81 Open T4
3" Vband out
$875
Brand new HX40
T3
3" vband out
$875
3g Lifters - $65
