Please Support STM Tuned
Please Support ExtremePSI
Hi guys i have fuel pump question
cesarv
Jul 25, 2013
moody, Texas
my relay keeps popping and im trying to find were is the fuel pump fuse is there any thanks guys
Yes i just installed a gsx on a Spyder my relay keeps popping and im just trying to figure if the fuel pump has a fuse other than that relay
As he asked what is the "pop"? If its the click it should do so once I believe when the car is cranked over and once when it stops. If it's continuosly clicking from the relay it could be faulty
Ok my light of fuel and gauge were showing, i was just just testing the wires because i put a awd tank on it so I put the key on it pop the relay for the fuel pump and i gess the lights one plus all the time that i turn of the car it pops, that secon d relay thank you for helping
Pull the fuse and see if it still frys the relay. If yes, you have a wiring problem, likely a short to ground taking out the relay.
Sorry guys, i don't have power for the fuel pump the relay is not sending signal when i go to start the carthe blue and black wire that feeds the pump doesn't whant to come on and second were is that fuse for the pump thanks
Would you please proofread your posts. We understand you have no power. Did you check power coming into the relay? Is the relay even turning on?
Yes there is power coming in to the relay true the other 3 wires
ok the relay is good i force the pump to turn on tru dsm link and it works
