wildbull mazula
- 0
- May 10, 2016
Dubai,
Asia
Hi guys,
A newbie here, I just had my 95 DSM 4G63T rebuilt the second time around due to crankwalk all necessary replacement have been done and still now holding back when I shift specially on the 1st and 2nd gear, it is also felt on the higher gears when I go beyond 4T. For a brief history of what's been done or replaced-My engine is kept stock, except for Quaife LSD, Walbro 400LPH, FP exhaust manifold, Apexi downpipe, ARP bolts, Cometic Stainless gaskets, Teflon Gasket for Intake manifold, Kings Tri-Metal crankshaft bearings, Gates Timing Belts, Nology Hot wires on NGK BPR7ES, Fidanza Flywheel, ACT clutch, AEM WideBand Eugo, Glowshift Oil Temperature Gauge, Manual Boost controller and Glowshift Boost Gauge, Aluminum radiator and silicone hoses, heads are ported and polished, tranny have been overhauled too. I run on 95 octane super, all sensor are replaced OEM brand new-CAS, CPS, water pump and oil pump OEM bnew, valve seals, piston rings, vacuum hoses replaced, my ECU now is EPROM, ECM-Link on stand by for tuning after 1T kms break in. (I still have a non EPROM ECU I removed for isolation of problem) Still on MAF, stock BOV (HKS BOV SQ IV removed for isolation of problem) and turbo kept stock still in great shape and spool. I haven't finished break in yet and it is already showing problems like this.
