Please Support Rix Racing
1G help with wierd knock?
alexs' tsi
May 3, 2015
Regina, SK_Canada
hey guys could you take a look at this data log i took and maybe tell me whats going on? it selectively knocks,, usually off boost with very little throttle input, any help is appretiated?
  • log.2015.05.05-01.elg
I noticed the car is idling at 2200 RPM @ 0% ThrotPos & 7.4 deg of knock.
But then your speed says 32MPH
So I think something is wrong with your throttle cable or you must have been cruising in neutral?
How long has it been doing this?
Is your maintenance up to date?
Have you done a BLT?
just got this motor in it not too long ago so its pretty fresh, that could've very well been cruising at neutral, i have done the belt when this motor was outside of the car and am certain the timing marks are spot on, its wierd becuase it will selectively knock, like you saw that knock there at 0% throttle, but when im on it and the car hits 8psi (wastegate) theres no knock at all
