Car Cannibal
- 533
- 58
- Jun 7, 2003
Chicago,
Illinois
Hi, I'm on my 3rd SD tune over the years on V3 and all 3 tuners seem to leave the idle and cruise around 14.3 AF/R (2nd guy had idle around 15.2 but cruised at 14.3).
I just had the tune done by a great tuner so out of respect I won't include their log. But the cars been inspected and is 100% good so there's no leaks or bad sensors.
How are you guys leaning out the SD tunes in closed loop?
I noticed that changing the SD map cells doesn't change anything because the cars in closed-loop. Then it doesn't matter if you mess with the maf comp settings because the box is checked in V3 that you're in speed density.
I'm afraid to mess with the injector deadtime because I know little about how it will affect the rest of the tune. I've read it has no affect at WOT or open loop so that's good because that part of the tune is killer.
Any tips will help, I have some familiarity with the program over the last 5 years so your recommendations won't go on deaf ears.
Appreciate it.
Appreciate it.
