bizie
- 129
- 3
- Jul 17, 2014
hagerstown,
Maryland
So I just got a 6 bolt and I'm looking for some specific information on what exactly the numbers on the build sheet mean. This is a brand new block built by Rob Fig? apparently he is a know name is the dsm world? I don't know because I'm new to all of this. I mainly want to know what exactly does .40 over mean? I know it is the bore being .40 over but then what would the displacement of the block be? It is on a stock crank and I'm just now learning about changing the crank for different displacement also, so I'm getting confused about how you get to a 2.3 liter? Is it by boring the cylinders or is it by changing the crank? So if I am .40 over am I a 2.4l? Sorry if this is a dumb question but aren't they all when you know the answer?
Also wanted to know if this means I need a special head gasket size? Do I go with the 85.5mm head gasket? I have 9.0:1 Compression ration cp pistons. Does this effect the head gasket I need?
For now this is all the noob questions I have but I'm sure I will come up with more since I still have to complete the block assembly and get it into my 2g gst. Thanks guys for any help.
