Please Support Morrison Fabrications
1G help with lean idle
alexs' tsi
May 3, 2015
Regina, SK_Canada
so i've got a 91 talon with a 2g maf, stock injectors and ecmlink v3 to run it, as well as a 3 inch exhaust, problem is when i go to adjust the biss screw to set proper idle using dsmlink to monitor isc position, the car will run lean (about 16:1) when you drop idle to a reasonable rpm (1000) but if you set idle too high (around 1400) it'll idle much better around (15:1) afr's. I'd like to firgure out why dropping the rpm's at idle to a reasonable value will cause the car to go lean? any help is appretiated
yup i have checked it with a multimeter and it has appropriate resistances, and as a matter of fact there is an exhaust leak i have just found today where the turbo elbow meets the downpipe before my wideband sensor, would that throw it off?
Yes that will throw it off. I had an exhaust leak in the same spot and my wideband read completely lean (22.4) at idle. As soon as I fixed the leak, it idled at 14.7 exactly like it should.
