smills1840
- 365
- 22
- Nov 8, 2011
Blacksburg,
Virginia
Alright, I'm attempting to convert to SD using ceddymods. I can't seem to get the Evoscan logging parameters to work properly though. I've attached a log with the following selected to log in Evoscan:
Engine RPM
Throttle Position
2Byte Load
2Byte AirCounts MAF
2Byte AirCounts SD
SD VE%
AirCount VE% Change
Battery Level
Boost Omni 4 BAR kPa
As you can see, the AirCount VE% Change is blank in the log, and I don't know why. Also, the 2Byte AirCounts SD is constantly at 3024, while the 2Byte AirCounts MAF fluctuates slightly like it should. What am I doing wrong here?
Engine RPM
Throttle Position
2Byte Load
2Byte AirCounts MAF
2Byte AirCounts SD
SD VE%
AirCount VE% Change
Battery Level
