1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
2G help purchasing new turbo
Posted by luigi90210, Apr 15, 2018
Please Support Ace Race Parts
  1. luigi90210
    luigi90210 Probationary Member
    7
    Joined Mar 11, 2013
    San Diego, California
    so I am on a budget right now and i wanted to ask what the difference between these 2 turbos are
    https://goo.gl/2K1jby
    https://goo.gl/cQNJqA
    they are both from the same seller and they both look the same but one specifically says its a garrett turbo the other says its their own in house brand
    i would like to have a reliable turbo but given im on a budget and i need my car running do you guys think its worth the risk buying the cheaper turbo? it looks like its a t28 core inside a t25 housing so i dont know how that will limit performance in any way or if its even a legit t28 core inside of it and not some china charger core
    my current setup is a stock 2g with BCS pill removed, a pod filter(came with the car), and a GFB evo 9 recirculation valve but i plan on upgrading everything, RC750cc injectors, wally 255, 3in turbo back exhaust, FMIC and a tune
    i know if i get the cheaper turbo i will just be running the 14.7-16psi my car runs now but i would like to eventually run 20+psi which the real t28 can do
    the better half of me is saying get the garrett turbo and do it right the first time but im really on a tight budget
    any insight would be appreciated
    Log in/Register to remove ads
  2. 007jimmy
    007jimmy Proven Member
    1,415
    50
    Joined Feb 27, 2012
    Levittown, Pennsylvania
    For the money of the cheaper turbo you stated above you could find yourself a good condition mhi 16g with all the install hardware that you'll need. Also the transition to a fmic will be a little easier in terms of piping later on.
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
      automatic
    Loading...
    ChessmoDSM and Twistaye like this.
  3. mitsumike0
    mitsumike0 Proven Member
    175
    26
    Joined Oct 13, 2013
    Passaic, New Jersey
    Search for Justmx141 on this website. Justin rebuild turbos and he might have something in stock for you at a much more reasonable price. He can also recommend you something for your goals that you have for your car as well.
    FYI, I've been running a a rebuilt 20g from Justin for almost 2 years now. My turbo has seen a few drag track days and many, many pulls and it still runs well.
    My DSM:
    Street Build
    12.32 @ 116.1 MPH
    Loading...
    Bud92gsx, 1990TSIAWDTALON and tk106 like this.
  4. Twistaye
    Twistaye Proven Member
    260
    4
    Joined Mar 22, 2007
    Lawton, Oklahoma
    I agree with picking up a 16g. You can find them anywhere from $250-350 shipped and PayPal'd. Up to you which you can find and your goals (S16G, Evo 3 16g or Big 16g). Get a used jpipe for $20-40 and you're all set. Then you know for a fact you have a geniune mhi turbo that will last. The suggestion for Justin is also good - he's been rebuildng turbos since I can remember and is awesome. Can't go wrong either way!
    My DSM:
    1996 Mitsubishi Eclipse GSX
    Street Build
      manual
    Loading...
  5. ChessmoDSM
    ChessmoDSM Proven Member
    137
    73
    Joined Apr 22, 2017
    Burlington, Vermont
    Rule #1, NEVER fawk with an Ebay Turbo if you have any love for your whip whatsoever.. Rule #2, see rule #1..
    Save up and get a name brand Turbo/look on here as there are turbo setups for sale all the time or reach out to Justin as stated above..
    Bud92gsx likes this.
  6. Vegas smith
    Vegas smith Proven Member
    1,960
    856
    Joined Dec 2, 2002
    Houston, Texas
    I wouldn't bother with either turbo. Contact @JusMX141 and see if he can get you a replacement. you're almost never going to come out ahead buying stuff on eBay.
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    GT30   manual
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
    Bud92gsx, 1990TSIAWDTALON and 19gsx91 like this.
  7. techboy
    techboy Proven Member
    134
    55
    Joined Feb 3, 2018
    Lehigh Valley, Pennsylvania
    I agree with everything already said about eBay turbos. If you absolutely must, I'd buy the Garrett one, the other is just a china copy that will be shot in 6 months and you be spending the money all over again.
    My DSM:
    1999 Mitsubishi Eclipse GST
    Street Build
    13.876 @ 106.97 MPH
    Loading...
  8. luigi90210
    7
    Joined Mar 11, 2013
    I'll check them out thanks
    eBay is a market place, I buy name brand stuff from there at discounted rates all the time, that's where I bought my GFB valve I currently use. I know what I can and can't use from generic eBay sellers and a turbo is not one of them which is why I'm asking about both turbos with one being a legit Garrett T28
    I'll check him out as well thanks .
    Also everyone there is a local turbo shop I'm thinking I should check out. Are there any downsides to buying a rebuilt turbo vs a brand new turbo? I'm leaning towards staying with Garrett turbos just because I don't want to have to change oil and coolant lines. I haven't swapped a turbo before so this is literally something I'm going into head first with no experience, but at the same time I don't really want to blow $900 on a new turbo if I can get a small 16g or something for cheap. I assume coolant lines are not hard to swap over? Also how different are the lines compared to a Garrett turbo and are there are companies selling an install kit? I would try eBay but for turbo related stuff I'd like to avoid generic parts unless it's simple things like piping.
    PlanZero likes this.
  9. PlanZero
    PlanZero Proven Member
    1,316
    244
    Joined Aug 13, 2013
    Easton, Pennsylvania
    Rebuilt turbos are the way to go. I bought my small 16G used and never rebuilt it since it had virtually no shaft play. I chose the S16G because of it's similarity to the stock t25 with quick spool up. It came with a SS feed line but everything else is stock. Coolant lines just need to be bent a little and you can use the stock oil drain.
    Is there a specific reason you're replacing the t25?
    My DSM:
    1996 Mitsubishi Eclipse Spyder GST (sold)
    Street Build
    T25   automatic
    1996 Eagle Talon TSi
    Street Build
    16g   automatic
    1997 Eagle Talon TSi AWD
    Street Build
    T25   automatic
    Loading...
  10. luigi90210
    7
    Joined Mar 11, 2013
    The T25 is smoking and puking oil on my driveway. I still need to tear everything down to actually see what the issue is but I'm pretty sure there is a bad seal in the turbo causing the oil to leak out and burn.
    Just kind of figured I would swap it for something bigger and a little more fun, I'm mainly looking for street ability so I don't want to have too much turbo lag
    I did find a parts car on Craigslist and it has almost everything I need outside of fuel system mods but I'm 90% sure the 16g on that car is an China charger since the owner didn't want to tell me if it was legit or not. I'm still kind of tempted though since that car has a manual trans and I'd like to have one in the event I decide to do an auto to manual conversion.
  11. Vegas smith
    1,960
    856
    Joined Dec 2, 2002
    Houston, Texas
    You can find used t-25s and such for $100 but of course they are used. If you want to switch to a 16g you'll need extra parts and you can search to see all you need.
    My DSM:
    Street Build
    GT30   manual
    16g   manual
    Loading...
  12. luigi90210
    7
    Joined Mar 11, 2013
    im aware, i have fuel system mods planned to support the turbo upgrade as well as a retune
    last thing i want is for my engine to grenade itself, it might be the first time im modifying my DSM but its not the first car i have modified, i just want to show my DSM the love it deserves
  13. 802gst
    802gst Proven Member
    47
    25
    Joined Feb 12, 2017
    St.albans, Vermont
    16g ftw! I run small 16g on both my cars n they rock! evo 16g if u don't mind a little lag. t28s are good I considered it back when I had a t25 but... for 9 bills hell no bud, that's a 16g bigger injectors wally 255hp and fmic. mhi will get you there and more for much cheaper
    My DSM:
    1998 Eagle Talon TSi AWD
    Street Build
    16g   manual
    Loading...
  14. Bud92gsx
    Bud92gsx Supporting Member
    7,867
    49
    Joined Jan 16, 2008
    Wisconsin, Wisconsin
    Justin JusMX141 will hook you up proper.
    Alot of us use,and have used his services.
    My DSM:
    1992 Mitsubishi Eclipse GSX
    13.300 @ 102.400 MPH
    Loading...
  15. Mauispyder
    Mauispyder Supporting Member
    351
    66
    Joined Jan 20, 2015
    Kula, Hawaii
    Got my T28 from the well respected JusMX141. It did everything I was looking for, a bit more power, especially from a dead stop going uphill. Crappy traffic signals on my mountain!
    Loading...
  16. Biddy420
    Biddy420 Proven Member
    117
    7
    Joined Jun 17, 2017
    Naperville, Illinois
    I run a pte 5031 love it not much mods needed other then blocking the coolant lines as it’s oil cooled only and the expected fuel mods has much more power then my evo iii 16g had
    My DSM:
    Loading...
  17. streetraceboi
    streetraceboi Proven Member
    345
    55
    Joined Sep 4, 2002
    San Antonio, Texas
    @JusMX141 for a turbo and/or rebuild! OEM or bust! With "eBay" turbos...you're running the risk of MOST LIKELY buying the turbo twice. Meaning, replacing the junk turbo with a turbo of quality. For the cost of the turbo initially mentioned, you can have a nice 16g setup which is a great turbo...as well as bolt ons on your wish list. Easily...a fun car with bolt ons
  18. doubleclutch
    doubleclutch Supporting Member
    670
    143
    Joined Jun 26, 2009
    Canton, Michigan
    My DSM:
    1998 Mitsubishi Eclipse GSX
    Street Build
    14.945 @ 93.64 MPH
    1996 Mitsubishi Eclipse GST (sold)
    T25   manual
    Loading...
    luigi90210 likes this.
  19. luigi90210
    7
    Joined Mar 11, 2013
    How is the lag with the 16g .My car is an auto Spyder, it's a street car so drivability is a must for me .
    Was there a huge lag difference between the T28 and the T25? With my car being an auto and a street car power under the curve is what I'm mostly looking for, I don't race the car so peak numbers don't really matter to me I mainly just want a car that drives nice and has a little more power than stock.
  20. streetraceboi
    345
    55
    Joined Sep 4, 2002
    San Antonio, Texas
    My gfs car is an auto 2g spyder as well. Evo2 16g. Mods are intake pipe, Greddy upper pipe w/Greddy bov catback, and mbc and she loves the car. Will be throwing in an Evo3 intake in soon to help with flow, as well as a pump and some injectors and a downpipe
  21. Mauispyder
    351
    66
    Joined Jan 20, 2015
    Kula, Hawaii
    I really didn’t notice any difference. It likes to be 2500 or higher to get boost well correlated with pedal height, I’ve also got an evo8 bov which direct fits and eliminates the prior leaky plastic 2g one.
    Loading...
Share This Page
Loading...
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Kiggly Racing Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto Spultronix Performance STM Tuned Tire Rack VR Speed Factory White Shed Speed
