Tony818
- 133
- 17
- Jul 15, 2015
Denver,
Colorado
I need your wisdom here on a mistake i made. I recently did an awd swap on a 99 spyder (gst) with a 95 gsx fuel tank. Well i been having this code pop up (p0446) (evaporative emisssion circuit) and after testing solenoids and conections i realized i dont have an evap canister. Because the gst had it in the tank (wich is now gone) and the gsx had it behind the front bumper (also gone) I also believe this is the reason for my high idle so i want to add it in. The problem is i wouldnt have the slightest clue on how to go about adding a canister in with all these lines mixed up. And would deleting the whole evap be easier? If i where to delete the evap system would that help my idle?Thanks for your time
