heat only works when driving
Posted by 93laser1g, Oct 31, 2011
Please Support Ace Race Parts
  1. 93laser1g
    93laser1g Proven Member
    223
    Joined Jul 24, 2011
    green bay, Wisconsin
    any idea why my heat only works when im
    driving at high speeds?
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. 91stocker
    91stocker Proven Member
    1,972
    73
    Joined Jan 15, 2010
    Vassar, Michigan
    Low coolant?
    Edit: Do you mean the blower motor/fan speed or the heat itself getting hot?
    My DSM:
    1991 Eagle Talon TSi AWD
    13.26 @ 102.09 MPH
    Loading...
  3. 2point3Tsi
    2point3Tsi Proven Member
    202
    Joined Jan 12, 2007
    Maple Valley, Washington
    Thermostat stuck open
    My DSM:
    Loading...
  4. BradM
    BradM Proven Member
    30
    Joined Nov 2, 2009
    Annapolis, Maryland
    +1 for low coolant. Had an Mr2 that leaked coolant, it happened all the time.
  5. CanadianTalonTC
    CanadianTalonTC Proven Member
    280
    4
    Joined Jul 8, 2011
    Lethbridge, AB, Canada
    Your thermostat may be stuck open and it only heats up with a higher load on the engine. What does the gauge on the dash say when your driving around the city?
    Check coolant level also like the guy above said.
    Joel
  6. Abe'sGST
    Abe'sGST Proven Member
    512
    Joined Aug 27, 2011
    Goldsboro, North Carolina
    i had that problem b/c this weekend i flushed my coolant. What i did wrong was that when i filled it with new coolant i closed the drain plug before i started filling it up. To make long story short, i had to "burp" my cooling system b/c i had air in it
    Loading...
  7. 93laser1g
    223
    Joined Jul 24, 2011
    my heat gauge is always right in the middle but drops down a little when the fan turns on.
    My DSM:
    Loading...
  8. CanadianTalonTC
    280
    4
    Joined Jul 8, 2011
    Weird, when I did mine I had my drain plug closed and it filled fine. How did you "burp" it?
    Joel
  9. ktgurl87
    ktgurl87 Proven Member
    835
    13
    Joined Sep 1, 2010
    Elizabeth City, North Carolina
    OP... what exactly is the problem? You say your heat only works while you're driving, then you say that your temp gauge drops when the fans kick on? That's normal.
    So are you talking about your temperature gauge... or the actual heater in the cabin of your car?
    Loading...
  10. Abe'sGST
    512
    Joined Aug 27, 2011
    it works like bleeding your brake lines, if you bleed the lines, tighten them up and then pour brake fluid in the master cylinder you will have air in the lines afterwards...i removed my radiator cap, started her up, run it at about 1500 rpms to let it get to running temperature and when the thermostat opens and coolant starts to cerculate the trapped air gets out, then i just top it off with more coolant
    what he's saying is that his heater doesn't work unless he's driving at cruising speeds
    Loading...
  11. natural laser
    natural laser Proven Member
    34
    Joined Oct 8, 2011
    Spokane, Washington
    My 91 laser seems to do the same thing, not moving its just pushing air, when im actually driving is when it heats up and actually blows warm air. and i checked my thermostat so in my case thats not the issue
  12. mb3000
    mb3000 Proven Member
    60
    Joined Aug 9, 2011
    Myrtle Beach, South Carolina
    Might have some blockage in your coolant system.
  13. Abe'sGST
    512
    Joined Aug 27, 2011
    if it's not the thermostat, it can either be some blocking in the colling system or air in it
    Loading...
  14. ramsack
    ramsack Banned Member
    2,196
    14
    Joined Dec 27, 2007
    West Lawn, Pennsylvania
    The heater core circuit is the primary loop. It will get a constant flow of coolant even if the thermostat is wide open, or non-existent. The temperature of the coolant entering the heater core is not controller, whatsoever. You probably have a blockage in the heater core, itself. Just get a new one and put aside a day to replace it.
  15. TSiAWDRatlemstr
    TSiAWDRatlemstr Proven Member
    31
    Joined Nov 2, 2007
    Boise, Idaho
    I have had this happen a couple times. Actually, it happened just two hours ago coming to work :) The first time that it happened, I had a small pinhole leak in one of the lines and the coolant leaked out once it was up to temp and the lines were pressurized. I checked the system with a coolant system pressure tester and found the leak. I replaced the line, refilled the coolant, bled the system of air (running with the cap off, filling up the overflow tank) and made sure that the thermostat opened. It happened again this morning, and it was a gusher! I know what I'm doing tonight :) The reason that the temp fluctuates, as far as I can figure out, is that there is still coolant being pushed through the system as the rpm increases to flow to the heater core, just not enough to flow at idle or low rpms. Happy leak fixing :)
  16. 93laser1g
    223
    Joined Jul 24, 2011
    okay i am talking about the heat inside the car. when idling i turn the blower on and nothing comes out of the vents, no cold air no warm air, nothing. when i start driving the heat begins to blow out of the vents. and the faster i drive the harder it blows. i need these solved asap as i live in wi and winter will be here soon and so will my baby so i need heat
    My DSM:
    Loading...
  17. mchustle
    mchustle Proven Member
    732
    Joined Aug 8, 2009
    johnson city, Tennessee
    Sounds like it may be your blower motor or simply a fuse.
  18. Archer Fabrications
    Archer Fabrications Supporting Vendor
    5,930
    630
    Joined May 9, 2011
    Scottsdale, Arizona
    +1 ^ op, you didnt say anything about the FANS not blowing ANY air.... again +1 to mchustle
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Drag Race Build
    11.128 @ 132.5 MPH
    Loading...
  19. Dsm78
    Dsm78 Proven Member
    31
    Joined Oct 10, 2006
    Fort Wayne, Indiana
    Try flushing out your heater core. If it is plugged up you will experience the problems that you are referring to.
  20. XLR8
    XLR8 Proven Member
    203
    20
    Joined Jul 7, 2003
    Kingston, New Hampshire
    Fuse might be having bad contact. I had a issue once on a car, I did every diagnostic I could and still not working. Turns out the fuse box had some corrosion in it, ended up having to tweak the sides of the fuse in opposite directions to get good contact. Ever taken apart a fuse box, layer by layer? It is amazing how everything is connected inside.
  21. blindboarder_02
    blindboarder_02 Proven Member
    159
    3
    Joined Oct 8, 2005
    Kenosha, Wisconsin
    I would say a bubble of air in the lines. I would try Abes post. He explains it perfectly. After you put the cap back on, fill the overflow so it can pull some if it needs any.
    Loading...
  22. casperfast
    casperfast Supporting Member
    526
    8
    Joined Sep 25, 2006
    Salem, Oregon
    the only reason you feel air when driving is due to the air blowing in cowl while you are moving. the blower motor is out or the fan switch in your dash. might be a fuse, but fuses dont blow for no reason. has nothing to do with the cooling system, coolant, radiator or the heater core.
    My DSM:
    Loading...
  23. knochgoon24
    knochgoon24 DSM Wiseman
    4,747
    60
    Joined Jan 29, 2008
    Troy, Michigan
    I had this happen when the coolant was really low. The coolant wouldn't circulate well until the rpm increased.
    EDIT: Just re-read the problem. Oops.
    Try checking the fuse. You can also test the blower fan by applying 12v to it. If it turns on, then you have a problem somewhere else in the the electronics.
    Loading...
  24. 93laser1g
    223
    Joined Jul 24, 2011
    okay does anybody know where the fuse is located?
    is it under the hood or under the dash b y the pedals?
    My DSM:
    Loading...
  25. Anubis_4_99
    Anubis_4_99 Proven Member
    730
    Joined Feb 26, 2005
    omaha, Nebraska
    I dont personally know, but why not just check both areas? Search for any blown fuses and address them.
    It is also possible that your blower motor has seized, or just plain stopped working. Try replacing the fuse, but if it is popped, and pops again, check your blower motor and make sure it spins freely.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
