1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
1G Head Surface opinion?
Posted by AlmightySo, Dec 21, 2017
Please Support VR Speed Factory
  1. AlmightySo
    AlmightySo Proven Member
    232
    3
    Joined May 1, 2014
    New Castle, Delaware
    Hey I just got my head back from the machine shop when they went to resurface the head it had a low spot and they welded it in and resurfaced it again. Looks like their welds have low spots too.. Amazing. What do you guys think?! I'm moments away from calling them an letting them know this isn't cool..
    Log in/Register to remove ads
    My DSM:
    1995 Mitsubishi Eclipse GSX
    Street Build
      manual
    Loading...
  2. AlmightySo
    232
    3
    Joined May 1, 2014
    Here's the pics. Right where the gasket seals
    My DSM:
    Street Build
      manual
    Loading...
  3. Turbo2g
    Turbo2g Proven Member
    269
    49
    Joined Oct 13, 2017
    Fallbrook, California
    You need to use a feeler gauge and straight edge to check it before complaining. Or have them show you with one that it isn't untrue.
    My DSM:
    Loading...
    iceguru1114 and GST with PSI like this.
  4. AlmightySo
    232
    3
    Joined May 1, 2014
    I meant pitting, welding pits.
    My DSM:
    Street Build
      manual
    Loading...
  5. chrysler kid
    chrysler kid Proven Member
    1,440
    336
    Joined Dec 20, 2002
    Mckinney, Texas
    I mean it looks alright. On a stock rebuild I'd say it should be fine
    Loading...
  6. AlmightySo
    232
    3
    Joined May 1, 2014
    Not stock, Goal is 30psi, roughly 500hp
    My DSM:
    Street Build
      manual
    Loading...
  7. AlmightySo
    232
    3
    Joined May 1, 2014
    Plan on going HKS gasket..
    My DSM:
    Street Build
      manual
    Loading...
  8. AlmightySo
    232
    3
    Joined May 1, 2014
    Anyone else want to share an input?
    My DSM:
    Street Build
      manual
    Loading...
  9. 2gmitsueclipse
    2gmitsueclipse DSM Wiseman
    2,016
    575
    Joined Jul 13, 2005
    Auburn Hills, Michigan
    Did you let the machine shop you had the head work done at know you planned to use an MLS head gasket?
    Has the block been decked in preparation for an MLS head gasket?
    If no to either, then run a composite head gasket (OEM or Felpro).
    MLS head gaskets require a rather high RA finish to properly seal. For example, Cometic recommends an RA 50 finish to ensure a proper seal.
    My DSM:
    1998 Mitsubishi Eclipse GSX
    Autocross Build
    T25   manual
    1999 Mitsubishi Eclipse GST
    Street Build
    16g   manual
    1990 Plymouth Laser RS Turbo
    Autocross Build
    14b   manual
    Loading...
  10. AlmightySo
    232
    3
    Joined May 1, 2014
    I told them I plan on running MLS and they said "You'll be good" he couldn't give me a RA sadly..
    I ordered a MLS, anyway for me to tell if a MLS is a mistake? Is there a chart for visual RA? Something close I mean
    My DSM:
    Street Build
      manual
    Loading...
  11. 2gmitsueclipse
    2,016
    575
    Joined Jul 13, 2005
    If I were in your shoes, I would run a composite.
    My DSM:
    Autocross Build
    T25   manual
    Street Build
    16g   manual
    Autocross Build
    14b   manual
    Loading...
    GST with PSI likes this.
  12. AlmightySo
    232
    3
    Joined May 1, 2014
    The surfaces are pretty smooth? Nothing catches my nail?
    Mainly want input about the pit welding with small pits in it.. Its right on the edge of the outer diameter of the gasket seal area
    My DSM:
    Street Build
      manual
    Loading...
  13. lasthope05
    lasthope05 Proven Member
    831
    170
    Joined Mar 31, 2006
    Philadelphia, Pennsylvania
    You'll be fine. Those pits are nothing to worry about.
  14. amsrn13
    amsrn13 Proven Member
    1,768
    417
    Joined Dec 1, 2013
    danbury, Connecticut
    I purchased a head with similar issues, worse in fact. Cars making over 600 whp on a hks head gasket. I wouldnt worry about it.
    My DSM:
    1992 Eagle Talon TSi
    Street Build
    645 whp   498 lb/ft
    Loading...
    AllanL likes this.
  15. GST with PSI
    GST with PSI DSM Wiseman
    1,725
    1,125
    Joined Jul 27, 2005
    San Diego, California
    Fel-Pro 9627PT and f***ing send it
    My DSM:
    1992 Mitsubishi Galant VR-4
    Street Build
      manual
    1991 Mitsubishi Galant VR-4
    Street Build
    12.030 @ 119.39 MPH
    1990 Mitsubishi Eclipse GST (sold)
    16g   manual
    1991 Mitsubishi Galant VR-4 (sold)
    Street Build
    14b   manual
    16g   manual
    Loading...
    Archer Fabrications and 93AWDDSM like this.
  16. chrysler kid
    1,440
    336
    Joined Dec 20, 2002
    Mckinney, Texas
    It's right there literally on the compression edge. I want to say screw it, but it still doesnt sit right in my mind
    I would take it back to the machine shop with your gasket to show them and discuss your options.
    I'd rather negotiate A discount on labor on another core than blow that chunk out during detonation.
    Loading...
  17. jakk220
    jakk220 Proven Member
    1,012
    146
    Joined Nov 13, 2010
    Akron, Ohio
    Spoken like a true DSM'er. I'm on a felpro composite and L19's at 30psi and holding strong.
    My DSM:
    1997 Eagle Talon N/T (sold)
    Autocross Build
      manual
    1993 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
  18. amsrn13
    1,768
    417
    Joined Dec 1, 2013
    hks that slut and send it......mls for the win. This is the way i look at it. If you install a composite and it works... fine. If u install a hks and its good.... your set for big power, if for some reason the finish is 2 ra off ...yah ok then install a composite . The money and time is worry it imo. Plus if the mls fails to seal. U have little to no cleanup unlike a composite. Keep your timing conservative based on the fuel your running and youll be fine. I still dont know why the mls spooks so many dsmers. On my hondas is literally rip the head off slap a new mls on and be boosting again 30+ psi......i still feel like these failures are more related to tuning issues vs install failures. Hks!!!!
    My DSM:
    Street Build
    645 whp   498 lb/ft
    Loading...
  19. amsrn13
    1,768
    417
    Joined Dec 1, 2013
    Ask me how i know? Go ahead ask me! ......yes, what?
    My DSM:
    Street Build
    645 whp   498 lb/ft
    Loading...
  20. AlmightySo
    232
    3
    Joined May 1, 2014
    I wanted to go HKS, might return the cometic mls I just bought. I just dont want to spend that amount and have it fail with a one time use type of thing LOL
    My DSM:
    Street Build
      manual
    Loading...
  21. amsrn13
    1,768
    417
    Joined Dec 1, 2013
    You will be fine.... do the hks. Best headgasket they make. My head was full of small pits. I said f it and its been holding close to 40psi from a 6266.
    My DSM:
    Street Build
    645 whp   498 lb/ft
    Loading...
  22. donniekak
    donniekak DSM Wiseman
    4,390
    679
    Joined Mar 23, 2008
    Surprise, Arizona
    That's from porosity in the weld. It shouldn't hurt anything. But they should have welded it in two passes to prevent it. It's almost impossible to get a clean weld on an old 4g head on the first pass. I weld, grind, then weld again.
    My DSM:
    1991 Eagle Talon TSi AWD
    Street Build
      manual
    Loading...
    Archer Fabrications likes this.
  23. donniekak
    4,390
    679
    Joined Mar 23, 2008
    Surprise, Arizona
    They'll torch like any other gasket.
    My DSM:
    Street Build
      manual
    Loading...
  24. GST with PSI
    1,725
    1,125
    Joined Jul 27, 2005
    That's the reason I like them. With composite gaskets, the gasket will usually torch before you see damage like that done to the head. The "fuse" theory, as I've heard it referenced to.
    My DSM:
    Street Build
      manual
    Street Build
    12.030 @ 119.39 MPH
    16g   manual
    Street Build
    14b   manual
    16g   manual
    Loading...
  25. chrysler kid
    1,440
    336
    Joined Dec 20, 2002
    Mckinney, Texas
    Loading...
Share This Page
Loading...
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Kiggly Racing Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto Spultronix Performance STM Tuned Tire Rack VR Speed Factory White Shed Speed
