Head lifting or bad headgasket?
Posted by stevetalon, Feb 17, 2010
Cylinder Head & Short Block - 4G63 cams, valvetrain, pistons, rods, stroker kits, 6-bolt swaps, hybrids, etc. Read this Forum's Strict Guidelines.
Please Support Race Components Inc
  1. stevetalon
    stevetalon Proven Member
    DSM Profiles:
    Aug 1, 2007
    135
    Frederick, Colorado
    So when i bought the car the previous owner installed a 5 layer metal head gasket. It has been running great for like 5 years on 14psi and has seen 18psi but recently i was pushing 19 psi with a peak timing of 22 on e85 and i starting pushing coolant and my temp would go up really fast. I'm not burning coolant or oil and they are not mixing. I freaked out when i got on it and my heater went cold. I did a compression check and its good and i pressurized the coolant system and it held pressure. I replaced the radiator cap. If i lifted the head could my 6 bolt geadstuds stretched and if the head lifted is the head gasket no good? It driving fine right now and im wondering if i should put in the arp's and see if it stops or should i just replace the headgasket with a felpro composite i have?
    #1
  2. iugrad92turbo
    iugrad92turbo Proven Member
    DSM Profiles:
    May 22, 2007
    10,155
    205
    Kalamazoo, Michigan
    If it lifte it seems more problems, i use oem head gaskets its a cheap part and arps, for some good insurance to a certain limit. Sounds like a head gasket is blown. I would just replace it with what you want, and see what happeneds, whats the worse scenario if you just change the gasket.
    #2
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
