half shaft
Posted by killab443, Jul 8, 2004
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support STM Tuned
  1. killab443
    killab443 Proven Member
    Nov 24, 2003
    570
    Howell, New_Jersey
    I have a 92 eclipse fwd turbo 6 bolt, I was wondering why the driverside axle is so long and there is no half shaft. Is a halfshaft better? could I just bolt up A halfshaft with a shorter axle to it or does aything else have to be done?
    #1
  2. crankbender
    crankbender Proven Member
    Apr 15, 2002
    1,167
    5
    houston, Texas
    You have a 1 piece drivers side axle? Are you sure the able isn't bolted to the back of the engine block with a carrier bearing?
    #2
  3. pinknuggit
    pinknuggit Proven Member
    Oct 15, 2003
    454
    joplin, Missouri
    no, it is a solid axle because i have one too. it just goes from the differential straight to the hub on each side of the car.
    #3
  4. crankbender
    Apr 15, 2002
    1,167
    5
    houston, Texas
    damn that sucks...
    The only reason you will need to upgrade is if you break it. I don't know about the placement of the carrier bearing on the 1g 7bolt block, but seeing as they have gsx versions that year there are surely half shafts out there for you to get.
    Next time you need to replace it you may want to try and locate one off a gsx...or just say you have a gsx at the parts store and it will probably fit. No guarantees though.
    #4
  5. DevilSperm
    DevilSperm Proven Member
    DSM Profiles:
    Oct 28, 2002
    1,477
    16
    Holdrege, Nebraska
    AWD's have half shafts, FWD's dont
    #5
  6. killab443
    Nov 24, 2003
    570
    Howell, New_Jersey
    dont you get a lot less torquw steer with a halfshaft
    #6
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
