KHRacing
- 162
- 0
- Dec 22, 2011
Kvidinge,
Europe
want to see this car done soon ###
Note: This feature currently requires accessing the site using the built-in Safari browser.
With everything I've been doing, I've liked the mat much better then woven. Maybe because my plugs have used the cheap stuff, but the mat has been stronger, formed shapes better, and been easier to work with. I dunno
The work you are doing here, this all has to do with the fact you cut the bumper up higher (and sheet metal behind it) and you sealing off the underside right?
Very nice, wear the blue gloves that Harbor Freight sells, everytime you get ready to work, also I would use the 3/4 oz. stranded mat instead of the cloth, it is cheaper and does not get as heavy as the cloth, so it stays more where ever you put it.
H B brushes loose their shape fast, I use the ones from Home D, they can be reused a lot more.
Man you are all a bunch of cheap asses!
Chip Brushes - Pack of 36 2" Industrial Grade Chip Brushes
36 brushes for 11 bucks. For 11 bucks, that cheaper then the acetone you'd waste cleaning 36 different brushes Natural bristles, 2 inches wide, seems to work perfect for me.
Not sure how many you'd need though for the project you are doing here though (well.. the whole aero kit project I mean). Thought I throw it out there anyways.
I know what you mean, hate throwing things away. But after 3 80 cent brushed failed to go soft after the "home depot special" resin hardens in just 10 effing mins, there ai t no saving it. Figure 10 brushes is about 8-9 bucks one at a time, so I said eff it, I'm buying a whole box
Look forward to more updates.
Reverse your procedure, add a little more resin to that first coat before you apply your material, then just tap your material on it to suck up the heavier coat of resin, it will make it easier to shape and not as messy, then only apply enough resin to cover your whites, it will also give you a better finish.
I dont like to use spreaders, I use a roller which is specially made for glass it has grooves and it comes in aluminum or plastic, if you dont know what it is, I can post a pic., the spreader grab an pull, the roller lets you use less resin,
By your pics it looks like you are using too much resin..
Use formica instead of plexiglass, it is a lot cheaper and easier for shapes.
Or a cheap cutting board from Walmart always worked for me.
Are you (and do you have to, assuming so) making new fender liners for the front wheel wells? The stock plastic wouldn't mate up with the wider front fenders correct?
