1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Good machine shop in Tampa bay area
Posted by cookb8419, Jun 6, 2017
Please Support JNZ Tuning
  1. cookb8419
    cookb8419 Probationary Member
    3
    Joined Apr 7, 2012
    Gibsonton, Florida
    Hello all, I'm looking for a good machine shop in the Tampa FL area that has a good reputation and knows what they are doing with our engines.
    I need the cylinders honed, crank checked and new pistons pressed on my stock 1G rods.
    Log in/Register to remove ads
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
    16g   manual
    Loading...
  2. miliman13
    miliman13 Proven Member
    1,538
    263
    Joined Jan 1, 2011
    tampa, Florida
    You're in the wrong section.
    Go to the local tab at the top of page .
    This has been discussed there already and you can use that info to make a decision .
    My DSM:
    Loading...
  3. cookb8419
    3
    Joined Apr 7, 2012
    Gibsonton, Florida
    I have tried the local section but I have not received any replies, also the discussions that I found on there about machine shops are not current and are many years old.
    My DSM:
    Street Build
    16g   manual
    Loading...
  4. miliman13
    1,538
    263
    Joined Jan 1, 2011
    tampa, Florida
    They still apply today ...
    Take my word .
    Try your local FB groups for recommendations since you require more up to date info.
    My DSM:
    Loading...
  5. 94awdcoupe
    94awdcoupe Proven Member
    1,174
    191
    Joined Nov 6, 2004
    tampa, Florida
    i used to build engines in tampa. can I ask why you are installing new pistons on stock rods? because when a piston or piston ring fails it always ruins the cylinder wall. a hone of cylinder cannot correct .
    My DSM:
    Street Build
    GT30   automatic
    Street Build
    20g   manual
    Loading...
  6. cookb8419
    3
    Joined Apr 7, 2012
    Gibsonton, Florida
    OK, thank you I will start checking out the shops in the local page.
    My DSM:
    Street Build
    16g   manual
    Loading...
  7. cookb8419
    3
    Joined Apr 7, 2012
    Gibsonton, Florida
    My cylinder walls have ring marks from being seized, I think. If you check out my profile I have pictures of the cylinder walls. I have a set of .020 pistons to go in on the rebuild.
    My DSM:
    Street Build
    16g   manual
    Loading...
  8. 94awdcoupe
    1,174
    191
    Joined Nov 6, 2004
    tampa, Florida
    okay. honed and bored are two different things.
    i used eisles machine shop
    My DSM:
    Street Build
    GT30   automatic
    Street Build
    20g   manual
    Loading...
    miliman13 likes this.
  9. cookb8419
    3
    Joined Apr 7, 2012
    Gibsonton, Florida
    94awdcoupe thanks for the recommendation I will be calling them.
    My DSM:
    Street Build
    16g   manual
    Loading...
Share This Page
Loading...
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Kiggly Racing Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
