Jacolu3
- 638
- 130
- Jan 31, 2015
Lake Grove,
New_York
So I've been slowly getting my parts together to do everything at once.
Purchased the car in the summer its a 2g gsx with about 120k miles on it.
My goals are 350-400 awhp and to be reliable. The motor is stock and the tranny is stock.
Here are the parts I've ordered so far. Let me know if I'm missing anything
FP HTA 68 with 84mm flow advancement internal wastegate
FP DSM race manifold with the porting option
FIC 1120 Injectors
Walbro 255 high fuel pump with rewire kit
Aeromotive fpr
Dsm link v3 full
VRSF fmic
Hks Bov recirculated
Oem composite head gasket
New timing belt with new tensioner oem
New water pump oem
Fluid damper harmonic balancer
New oem coil pack
New ngk plugs
Dsm connector kit from jnz (to replace all the sensor connections that are cracked)
Pro sport boost gauge and pro sport oil pressure gauge
Arp head studs
New balance shaft belt and tensioner
Innovate mtx-l wideband
New turbo oil feed line
New turbo return line
New manifold studs
New turbo to manifold bolts
So I think that's it
Let me know if there is something I'm missing.
Thanks
Brian
FIC 1120 Injectors
Aeromotive fpr
Dsm link v3 full
VRSF fmic
New water pump oem
New oem coil pack
New ngk plugs
Arp head studs
New manifold studs
Thanks
Brian
