1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
General injector installation tips & RCI injector hassle
Posted by 4gfun, May 12, 2018
Please Support Feal Suspension
  1. 4gfun
    4gfun Supporting VIP
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    I purchased RCI 1200cc injectors and installing them has always been a nightmare.
    With my FICs I can just put the top of the injector into the rail and use care/common sense and install them very easily.
    With the RCI injectors, if you try to do that, the injectors loosely fall out of the top of the rail which frightens the crap out of me.
    In speaking with RCI, they suggested that I install the injectors into the head first.
    Not having any luck with that method either. If you slide the injector into the head the seal doesn't want to go in all the way and the injector pops out when you need it to stay put the most. If you put the seal into the head first, it is too tight and the injector pops out when you need it to stay in most.
    Having this level of complication has caused me to break the seals going into the head forcing me to buy new seals at my expense only to rinse and repeat this hassle.
    FWIW they have been referred to as Lucas injectors and Delphi injectors if these are tougher to install.
    The injector o-rings are well lubed.
    Help!
    Log in/Register to remove ads
    My DSM:
    1994 Plymouth Laser RS Turbo
    Street Build
    16g   manual
    1991 Mitsubishi Galant VR-4
    Street Build
    16g   manual
    1993 Eagle Talon TSi AWD
    Street Build
    14b   manual
    Loading...
    Featured Products from our Supporting Vendors
  2. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    So I ended up breaking the middle injector rail bolt due to the seals going into the head being effectively too large. I put the FIC injectors back in just to be able to move the car and I installed them in the head FIRST with no problem. If I try this with the RCI injectors the injectors pop out with the slightest breeze!
    Can I just install smaller seals at the end of the injector?
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  3. bastarddsm
    bastarddsm Supporting Vendor
    4,203
    825
    Joined Aug 26, 2003
    Mendota, Illinois
    Pics of injectors and seals
    My DSM:
    1991 Eagle Talon N/T
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
    4gfun likes this.
  4. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    I can hardly move, LOL! I was thinking of doing this, but wasn't sure if anyone was listening. Guess you are. Let me get some pics.
    Thank you.
    PS - I think it will be best to provide tons of pics. I will provide pics in increments to get started. Please be patient while I brave Photobucket popups. For whatever reason, the angel of death never passed over my free account. :idontknow:
    NOTE: PICS UPLOAD COMPLETE FOR NOW, PLEASE LET ME KNOW IF YOU WOULD LIKE TO SEE ANY OTHERS
    Please note the following:
    1) The injectors have the following information on them:
    a) 12 LB7HR
    b) 0084
    c) 01D134B
    d) RCI
    e) 1200
    2) In one of the pics, I included and numbered the injector seals that came with the injectors before I had to replace them.
    When I received the replacement set, seal "1" was black not green. The green o-ring is bigger than the 2 black o-rings that I received to replace seals "1&2". In either event, the green o-ring is still a bit small for the fuel rail.
    I also included pics of the old o-rings because that green o-ring might help identify the injector.
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  5. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  6. motomattx
    motomattx Proven Member
    950
    186
    Joined Dec 9, 2010
    wampum, Pennsylvania
    Those appear to be Delphi/GM injectors that have been thrown in a lathe and turned down a little, I have the Delphi's and the same seals came with them and I went through the same thing years ago when messing with them, I learned to put the seals into the head first and then force the injectors into the seals after all four injectors are up in the rail, I just bolt it down evenly and call it a day, I used the non grooved seal, basically the stock seal setup and up top I used the green seals.
    My DSM:
    1995 Mitsubishi Eclipse GST
    Drag Race Build
    GT42   manual
    Loading...
    4gfun likes this.
  7. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    Hey, could you expand on the lathe and turned down a little. I am familiar with a lathe but the turning down part...hmm. :)
    I like your tactic, but the injectors keep falling out from the rail...It is like a balancing act with these injectors where the FIC lock in there like a vacuum is sucking them in LOL. Did you have the falling from the rail problem?
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  8. motomattx
    950
    186
    Joined Dec 9, 2010
    I just meant that it looks like they put them in a lathe and take the top green layer from the GM injectors to make them look like shiny bare metal, if they are in fact Delphi's (they very well might not be at all) they come from the factory with a green like coating on them. You can try some thicker O-rings up top if you need to, just run down to your local Napa and ask to see some injector seal kits that they have in stock and take your rail and choose ones that give a nice tight fit.
    My DSM:
    Drag Race Build
    GT42   manual
    Loading...
    4gfun likes this.
  9. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    Thanks boss, pretty interesting info here. I have some unused upper injector seals laying around that I could try.
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  10. bastarddsm
    4,203
    825
    Joined Aug 26, 2003
    Mendota, Illinois
    Those are not gm delphi, those are standard motor products that are sold by accel, holley trick flow FIC ect. They are a domestic injector modded for dsm fitment. I use the same ones in my car. What I would do is omit #3, and use a normal dsm insulator for #4. You can get them at oriellys. It's BWD part for a 90's toyota tacoma with a 1.8 or some little 4cyl.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
    1990TSIAWDTALON likes this.
  11. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    Best Answer
    Wow dude, thanks so much for this!
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  12. bastarddsm
    4,203
    825
    Joined Aug 26, 2003
    Mendota, Illinois
    They are loose on the injector, but it seems to work for me.might need to put an oring in place of #3 to help hold it down.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
    4gfun likes this.
  13. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    Thanks for the info. I'll let you know how I make out! Will probably be a bit.
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  14. Twinturbo120
    Twinturbo120 Supporting Member
    356
    9
    Joined Aug 14, 2010
    Miami, Florida
    If they are RC 1200 injectors, be aware that they are actually 1000 cc injectors.
    They use a base fuel pressure of 55 PSI to get 1200cc's.
    If you drop it to our base fuel pressure, it drops down to 1000cc's.
    Useful information when you are dialing them in, just fyi.
    4gfun likes this.
  15. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    I think that RCI injectors are a bit different than RC injectors. I knew that about the RC injectors but not sure about these. Thanks.
    http://www.racecomponentsinc.com/Products-Fuel_Injectors.html
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  16. Twinturbo120
    356
    9
    Joined Aug 14, 2010
    Miami, Florida
    Oh crap LOL, must have skimmed too fast, thought they were RC injectors.
    4gfun likes this.
  17. 4gfun
    1,809
    39
    Joined Dec 10, 2007
    Ask Me, Virginia
    Lol! It happens to me all the time. Thanks for joining the thread. :)
    My DSM:
    Street Build
    16g   manual
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
    Twinturbo120 likes this.
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
