lewishamilton
- 154
- 2
- Oct 11, 2011
Here,
Maryland
I've searched and read the few threads on wiring boost gauges to the dimmer switch but none really explains what I did wrong on my install.
I'm getting the gauges dimming opposite of the rest of the Instrument Panel (So Speedo bright = Gauges Dim and vice versa)
"Check the polarity. Before you solder anything, make sure the polarity is correct. Nothing will be damaged if it is not. If you have the polarity correct, as you rotate your dimmer switch the gauge light should get bright and dim along with the rest of the instrument lights. If you have it hooked backwards, as the factory instrument lights yet brighter, your gauge light will get darker. It will be the opposite of what the rest of the gauges are doing. If this happens, just switch the wires and you'll be set."
This is written on a step by step (I checked the site and the VFAQ
This seems like exactly what happened but I'm not sure how to fix it. Which wires should I switch? Right now I'm getting power at the stereo, ground next to the stereo under the console and the lighting wire at the dimmer. My gauges are getting power and working fine except for the dimming being the inverse of everything else. (It wouldn't be a problem except my gauges are extremely bright and distracting, I want a more OEM look)
