Gas tank wont fill up?
Posted by darthvadar tsi, Oct 21, 2011
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Kiggly Racing
  1. darthvadar tsi
    darthvadar tsi Proven Member
    DSM Profiles:
    Nov 9, 2010
    123
    Columbus, Ohio
    When I fill up at gas stations it only takes 20 cents at a time. I have been reading that the gas tank isnt venting properly and is clogged. Is there any diagrams I can look at to see how to take it off and What would I be looking for clogs etc?
    #1
  2. obsidian
    obsidian Proven Member
    DSM Profiles:
    Jun 25, 2007
    344
    New Orleans, Louisiana
    Mine did this for awhile. I have a 1g so it's probably different. In my system was this little blue check valve. It has a diaphram on the inside of it that was stuck closed and was not venting. I removed it, filled it with wd-40 and used a small tool to prod the diaphram until it was loose. Then I dumped wd-40, refilled, reworked. over and over until I was satisfied.
    I then reinstalled and haven't had the problem since.
    #2
  3. darthvadar tsi
    DSM Profiles:
    Nov 9, 2010
    123
    Columbus, Ohio
    Where is the blue check valve is it by the tank im sure the 1g and 2g arent too much different in that department. Thanks for the post.
    #3
  4. nuclearr
    nuclearr Proven Member
    DSM Profiles:
    Jun 22, 2004
    1,201
    11
    Slidell, Louisiana
    The check valve is in the smaller line going from the fill neck to the tank. Look in the passenger rear wheel well.
    #4
  5. kchaazz
    kchaazz Proven Member
    DSM Profiles:
    Oct 2, 2002
    1,121
    61
    PENSACOLA, Florida
    The blue check valve on the 1G is on top of the tank, near the sending unit. This is on the AWD. I think the 2G unit is beneath an access panel that is under the rear seat but I dont remember if thats AWD or FWD on the 2G.
    #5
  6. darthvadar tsi
    DSM Profiles:
    Nov 9, 2010
    123
    Columbus, Ohio
    Do I half to drain the gas tank out in order to take off the valve? I still havent found it I see a line by the neck coming toward the gas tank but im not totally sure. I wish there was a picture or diagram of some sort to look at to find it.
    #6
  7. obsidian
    DSM Profiles:
    Jun 25, 2007
    344
    I didn't. The blue valve is for releasing pressure out but not letting anything bad come back in.
    I have no clue where it is on the 2g. Just follow the line from the fuel tank that has no fuel in it and see where it goes. If you can't find that line, see if you still have the carb canister up in your engine bay and follow the line that says "fuel tank" back and that one will bring you straight to it.
    This is assuming the 2g even has that canister.
    #7
  8. Colt4G63 also
    Colt4G63 also Proven Member
    DSM Profiles:
    Jul 23, 2008
    2,670
    44
    Tonawanda, New_York
    This "canister vent valve" should open when you shut the car off, and let the air escape from the tank so you can fill the tank. Check inside your front bumper.
    I've seen other makes run into the symptom you're having, and it was always this.
    [​IMG]
    #8
  9. darthvadar tsi
    DSM Profiles:
    Nov 9, 2010
    123
    Columbus, Ohio
    is this picture of the blue valve? Was that located on the driver side behind the front bumper? Im seeing something similar to it.
    #9
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
