enriquez2000
- 2,277
- 820
- Oct 5, 2014
fort collins,
Colorado
I just want to verify that this diagram is correct.
Way i understand it is use the relay in between the blue wire(blue wire mod), ground to chasis with resistor in place off relay, supply 12 volt from battery and splice into fps to ooen the circuit.
With ecm link this should produce full line pressure after whatever tps% you input correct? So if i want full line shifts at 70% and up change that parameter.
Just want to clarify before cutting wires.
