HallerDSM
- 53
- 4
- Sep 10, 2013
Mentor,
Ohio
1990 Eagle Talon TSi fwd.
So a few weeks ago i left a buddy's house and barely made it home. When i pulled in, smoke had surrounded car and started to fill cabin. I was able to trace the source down to fuel pump wiring harness. (melted mess) Just happened outta the blue.
Figured i had a short and replaced harness with good one from donor car. Started car and bam instant smoke, harness fried all the way down to the cabin connector again. Cut open harness and found the culprit is the ground wire coming from the fuel level sending unit even though the gauge functioned properly until I shut off the car. I replaced the sending unit with a functioning one from another car and replaced ground.
Started car, and again burnt up the ground instantly. Next I replaced the ground with larger wire directly to chassis and still same result, burnt ground right after i start the car. I ran new sending unit wires and a new ground still over loading and burning ground. Replaced gauge with new one and same results.
No matter what Ive tried there seems to be too much resistance going through the ground wire instantly over heating it. The car runs fine when the connector for sending unit is unhooked, and the gauge works perfect with the key at the acc position. I know the sending unit, gauge, and wires (other than ground) are all good.
The problem arises when i start the car the ground instantly burns up. I'm thinking something could be causing a positive ground issue since there is very minimal resistance produced by the sending unit itself. (Although nothing else seems to be affected). I'm going to be checking my chassis grounds next but any other thoughts or suggestions would be appreciated.
This just isn't making sense to me, I'm scratching my head on this one. P.S. I have a Walboro 190-rewired with external relay that seems to be functioning normally.
