Please Support ExtremePSI
2G Fuel pump rewire question
96talonchick
202
10
Feb 3, 2016
Chippewa Falls, Wisconsin
My AWD came with the rewire already done however, I am trying to figure out where most people put the relay. I will be using the rear seat often and was told I needed to move the relay from it's current location, mounted off the fuel pump plate.
My relay is mounted behind one of the plastic panels in the back, close to the tank but your a 2g so the pump is under the seat. The relay won't care where it is, but you do want to keep the wire that goes to the pump as reasonably short as you can. It is just a switch that gives the pump full battery voltage and I don't see it dropping much if you were to mount it a foot or two away. My .02 :)
x2 for me as well. Behind the plastic panel. I actually used the same white plastic piece that holds the loom in place that runs to the fuel pump hangar assembly to neatly run it in that direction.
Can anyone by chance post pictures? And the wires are currently included with the white wire protector. I just need to know where the best spot to put the relay is. Also out of the way of the plastic panel.
