david harker
- 30
- 0
- Jun 11, 2014
Hagerstown,
Maryland
Ok so I think my o rings might be bad in all of my 1050 injectors which is weird because this has never happened .in the pic I posted you can see what looks like fuel/ oil and smells like fuel. You can see the small puddle where I'm pointing and there is the same Fluids in each the other 3 spots under the injectors. . Could it be a mixture of valve cover leaking and o rings bad ? Also isn't weird there are puddles under every injector ? Could it really be all 4 rings happen to go at the same time ?i think I figured it out but not 100%
