shartlza
- 0
- Sep 6, 2009
RSM,
California
It is time to let her go. Car is in OC California. Please email me directly at [email protected] if you are interested. Car has 79,532 miles on it. I am starting the asking price at $6000, but I am willing to hear any offer!!! I have listed the modifications that I could think of off the top of my head below as well as some photos. Car is not CA smog legal. If you have any questions or want more details or pictures just shoot me an email. Thanks for the space!!
Modifications:
-6 bolt 2.0l w/ Wiseco 8.5-1 comp. pistons attached to Eagle H beam connecting rods (roughly 20k on)
-Ported and polished head w/ ss valves, shimmed springs, and 2g lifters
-HKS 272 exh/int cams
-SS head gasket w/ ARP head studs
-FP Red turbo w/ 7cm exh housing and WG welded shut for exh mani external WG, perfect no shaft play (about 15k miles)
-HKS 40mm external WG dump to atmos on ported 2g exh mani
-BR cold air intake
-2.5in o2 housing to 3in exhaust strait through, no cat
-Indy core large FMIC w/ BR 2.5in polished ss short route IC piping w/ Tial 40mm BOV
-Mustang 2.5in TB
-Polished Forrester cast intake mani w/ phenolic spacer
-ShepTrans stock rebuilt tranny, perfect shifts (about 30k miles)
-2600lb clutch pressure plate w/ stock disc
-SS clutch line
-AEM EMS w/ 3 bar map sensor, set to speed density
-HKS turbo timer
-HKS EVC EZ boost controller
-Supra fuel pump w/ direct wire
-720 denso fuel injectors
-FPR bolted directly stock fuel rail
-Coil on Plug setup with stock ignition
-Gauges: autometer 30-30 boost gauge, autometer egr temp gauge (both on A pillar), AEM Uego wide A/F gauge (in stock gauge cluster where oil pressure gauge was), and SPA design split digital fuel pressure/oil pressure gauge
-All emissions elim and A/C removed
-AGX adj struts w/ I think 2in drop springs
-Rear toe adj arms (not installed)
-SS brake lines, powerstop slotted rotters, hawk
Engine
Console
Interior
Modifications:
-BR cold air intake
-Mustang 2.5in TB
-SS clutch line
-HKS turbo timer
Engine
Console
Interior
