Please Support STM Tuned
FS: CompWorks 2G Fender Braces
greengoblin
Supporting Vendor
1,571
392
Mar 10, 2006
McKinney, Texas
I'm currently sold out!!
CompWorks 2g fenders braces are built from precision notched DOM tubing.
The mounting plates and brackets are cut on a high def plasma table and then bent on a CNC press brake for precision and accuracy.
They are then iron phosphate washed to improve corrosion resistance and top coat adhesion. A satin black powder coating is applied providing an attractive and extremely durable finish.
The fender braces are designed to provide a rigid link between the A-pillar and the front chassis just before the strut tower area limiting deflection under braking and cornering loads. Like the role of a strut braces is to stop side to side forces, the fender brace works to eliminate vertical movements. This helps maintain the suspensions geometry and greatly improves steering response.
The braces weigh about 2.3 LBS per side.
CompWorks 2g fender braces have two mounting option for you to chose from.
Option 1 :
The bolt in design requires the inner fender to have two holes to be drilled for the braces to bolt to and a third access hole drilled for a sandwich mounting plate to be inserted.
Option 2:
The weld in design requires a window be cut into the inner fender and the supplied mounting plate welded into position.
I will gladly assist in deciding which option is best for your needs.
Cost is $250.00 shipped in the lower 48 states.
My paypal is [email protected]
Thanks and I look forward to working with you,
Kevin Kovatch
208-830-1193
