FilmerDude
- 201
- 6
- Nov 10, 2014
Temperance,
Michigan
My O2 sensor only reads .02 to .03 volts and I replaced it and it still shows the same readings. I am using ecu+ to read the output. Any idea what's going on?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Have you tried different mafs? I had the same problem where my 02 didn't cycle because of a bad maf.My O2 sensor only reads .02 to .03 volts and I replaced it and it still shows the same readings. I am using ecu+ to read the output. Any idea what's going on?
