casuprock
- 320
- 3
- Apr 13, 2010
Exeter,
New_Hampshire
I woke up one day and thought "Wouldn't the world be a better place if there were a way to use a flashable 98/99 ECU on a 1995 2G DSM without having to retain the OBDII?" In 1996, OBDII became mandatory... but the 2G ECU remained backwards compatible. What if you want to run Ceddymods on your 1995? Should you be forced to have OBDII on the vehicle?
Today is the day that birds are singing in the trees, flowers are blooming, and the skies are blue. A light shown down from the heavens and graced my ECU with a ROM free from the chains of OBDII... (i.e. I got help from Acamus) If you care to thank Acamus for his help, he accepts donations. Make sure to tag this thread as helpful.
While this ROM will work on any 2G with a 98/99 ECU, DO NOT USE THIS ROM ON STREET VEHICLES MADE BETWEEN 1996-1999. While OBDII is not required on 1995 vehicles, it was made legally mandatory in 1996. Don't do anything illegal. Think about it, your mom would be upset if you got arrested.
I updated this patch with the table data from Ceddymod (hence the file name). Here is the patched 2G ROM and metadata.
Flashed with EcuFlash using an OpenPort.
The result is self-explanatory.
