Please Support RTM Racing
For you Holset guys, JNZ has the N/T Water Pipe in stock!
Oh nice! Wish I found this when I had everything apart. I have coolant caps on them ports now, But if everything comes out again I'll be switching to the N/T pipe for sure.
Just weld the ports closed. I had mine welded closed. Worst case scenario, use JB weld.
JB weld would hold the water pressure at 200 degrees??
I jb welded a bolt in ahose and clamped both to the barb. Been fine here for all kinds of hot temps.
I had something similar before I welded it up. Machine screw in a hose with high temp silicone and a ring clamp. No leaks, but it looked ugly. So when I pulled the motor I also cut the water pipe nipples (leaving about 1/4 inch) and welded them shut. Sprayed the whole pipe with some paint and Bob's you uncle.
