First Engine Rebuild 420a, I need some help
Posted by DeathJunior, Jun 17, 2017
Please Support STM Tuned
  1. DeathJunior
    DeathJunior Proven Member
    32
    Joined Jan 19, 2017
    Springfield, Missouri
    Alright so I picked up my first eclipse ever earlier this year and It has a spun rod bearings internally and I have no idea for how long they have been like that. However, I really don't trust the original owner to have taken care of it since he let it sit for the last 2 years and he told me the reason why was the ALT. The ALT is fine but the engine rattles around 4k and above. So because the rods are probably going to need to sent to the machine shop anyway and I had access to a fresh block with new crank bearings and fresh crank for 50 bucks I just decided I'd go with an all new or remanufactured short block that I would build in my garage. This means block, pistons, rods, and a freshly rebuilt head and cams. It also allows me to rebuild the majority of the engine outside of the car meaning I can move it around my driveway for a bit longer while I build.
    I'm starting on the rod and piston assembly asap and the first issue I'm running into is how the rods are supposed to go. My new pistons have a F for front and an STD and arrow point which way goes towards the front of the engine. However I have no idea which way the rods go and my haynes manual doesn't say anything about it. These are press in so finding out is fairly important because I really can't go back if I make a mistake. Here's hoping someone on here knows which way the rods go on a 420A. I'm assuming the print on the side of the connecting rod goes forward but I really don't know.
    Any help would be awesome thanks
    Log in/Register to remove ads
  2. DeathJunior
    32
    Joined Jan 19, 2017
    well alright apparently no one knows the answer guess I'm just going to wing it
  3. DannyE
    DannyE Proven Member
    87
    17
    Joined Dec 2, 2016
    Charles Town, West Virginia
    Not to familiar with the 420a but I do believe that the letters/numbers face the timing belt side as in the 4g's, one thing you do not want to do is mix up the the rod caps because they go in a specific orientation. Hope this helps you some bud.
    My DSM:
    1993 Plymouth Laser RS Turbo
    Drag Race Build
    20g   automatic
    Loading...
  4. dsmcrzy
    dsmcrzy Proven Member
    1,083
    190
    Joined Dec 20, 2009
    Trenton, Ohio
    Are these stock rods?
    My DSM:
    1996 Mitsubishi Eclipse N/T
    Street Build
    20g   manual
    Loading...
  5. dsmcrzy
    1,083
    190
    Joined Dec 20, 2009
    Trenton, Ohio
    Also have you taken the block to a machine shop to ensure the bores are true (straight) and don't need any material taken off? If they are still true you will need to do a home at the very least to help the rings seat properly.
    My DSM:
    Street Build
    20g   manual
    Loading...
  6. DeathJunior
    32
    Joined Jan 19, 2017
    They are refurbished rods that I ordered as a set of 4, they have been refinished and prepped. I already installed all 4 with the freeze and heat method and a 3D printed jig I made. I figured out orientation by using a post in the neon 420a forums. I checked with my machine shop and I got it right however I may take one of the rods to the machine shop just to have them press one of the wrist pins in just a bit further since its off center by about a millimeter and I'm shooting for perfect. This should be a straight forward rebuild though the crank in this engine is likely dead so I have a freshly remachined crank shaft waiting and a set of .025 over bearings prepped. I'm replacing the head, pistons, rods, crank, and I have a set of crower stage one cams on the way. I figure why put the old cams in a new head if I can drop in a slightly better set. Then I'll build an 8psi turbo setup for it once I've finished fixing the headliner and built the audio system for it.
    spyderdrifter likes this.
  7. spyderdrifter
    spyderdrifter Supporting Member
    3,138
    238
    Joined Jul 11, 2009
    Colorado Springs, Colorado
    Good idea to get the wrist pins pressed a bit more. Can't go wrong with a double check :thumb:
    My DSM:
    1997 Mitsubishi Eclipse Spyder GST (sold)
    Street Build
    T28   manual
    1996 Mitsubishi Eclipse GSX (sold)
    16g   manual
    1996 Eagle Talon N/T (sold)
      manual
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory White Shed Speed
