Please Support STM Tuned
2G First Build: Too Much At Once...
njclimber36
65
Mar 18, 2011
Toms River, New_Jersey
I bought a 95 TSI AWD auto with a blown trans a couple years ago. I rebuilt the transmission with an IPT rebuild kit as well as a restalled converter they did. My goal has been about 300 to 350 wheel horsepower. Since that time, I have been driving the car now and then and collecting parts for my first build. This is my first turbo car and I am just as interested in durability as I am making power. Here is what I have gathered up so far:
Rebuilt 7 bolt head, street port job done by Head Games in NJ. Kiggly HLA, 3g lifters, Ferrara SS valves, Map behive springs and EVO retainers. I have HKS 264's, EVO rockers and Fidanza cam gears.
L19 Head studs
VSRF front mount with GM MAFF.
Mishimoto 3 row X line radiator
Dual Flex-a-Lite fan setup
Evo 3 intake
1g throttle body / rebuilt/bored to 63mm
FP intake pipe
NGR BOV to atmosphere
Link Version 3 full
ID1000's
Walbro 255 / rewire kit
Aeromoto AFPR
O2 Dump with Tail 38mm MVR
3 inch exhaust / no cat
Gates Kevlar belts, new water pump, tensioner pulleys.
Fluid Amp dampener
FP exhaust manifold
Garrett Gt3071r
With the recent deal on the 68HTA, I am considering starting off with that instead of the 3071. If I go with the HTA, am I better off with stock cams? I would like to do something with the PCV system, but with changing almost everything except the short block at the same time it seems like too much at once. I am worried if I get something wrong, I won't know where to start looking. I'd like to do the job once the right way.
Any thoughts on how to go about it? Which turbo / cams? Am I missing something?
PS. I have read a lot and I feel like I have picked up the right parts for what I want to do. If I want to go bigger later on, I will buy a bigger turbo. I am more interested in keeping spool as low as possible for a fun street car. It isn't my daily and if the bottom end goes I plan on building a 2.4 long rod. I have seen a lot of threads "Just get a GT42R or your a pansy". I don't need to compensate for anything, so if you could keep that mentality to yourself, I would appreciate it. Thanks in advance.
The 68HTA is basically a 16g on steroids. The price that I payed for my 68HTA bundle a few months back I could have bought three on this deal going on. Its all good tho. I am also going to run stock cams with this turbo so ill be looking at other members inputs.
Are you going speed density? Curious because you said bov vented to atmosphere?
The GM MAFF is after the BOV, so venting to atmosphere won't be an issue.
You have a list of parts alright. You state you know what you want to do but dont tell us. objectively and subjectively what do you want to do? Maybe this will help.
http://www.dsmtuners.com/threads/project-management-and-building-a-dsm.421705/
I guess I kind of mixed in my goals in the post instead of clearly stating them at once. I am looking for a quick spooling, fun street car and my power goal is somewhere between 300 and 350 at the wheels. Thanks for the link. I have read a lot, but not sure about that one yet.
I'll be running hks 264's with my 68hta. Should be a nice combo for the turbo. I was previously running bc272's with my s16g and had great gains. So it seems the 264's would be perfect for the 68hta in my opinion.
You wouldn't happen to have a dyno chart for the HKS 264s with a 68HTA would you? I am not sure if going with the 71r would be more beneficial or not and looking to compare so. I haven't found any direct comparisons in searches.
