MrCup
- 66
- 0
- Mar 25, 2013
Tempe,
Arizona
so i put a FIAV and ISC block off plate (Made my self) on my car (97 gst with 98 ecu). the idle works like a dream when it is at running temp but any temp below that it idles vary low. I know if i put the isc back on and just block off the FIAV it will most likely work right. i don't want that big hunk of junk on bottom of my TB. I live in Tempe, AZ it doesn't get ti freezing here so i should be just fine with out it. does anyone know how i can make it idle right at 850 with out the ISC when its below running temp? i have ceddy flashed.
my first idea is to trick the ecu into thinking that it is running at running temp all the time. i would do this by unplugging the coolant temp scencer and putting in a resister (300 ohm) sense thats the way the thing works. leave the coolant sending unit pluged in so it will still read on the dash. if it wont read on the dash i have a gauge that i can install to give me the temp of the car.
now with all that said the bad thing is that if the car does get hot then the fans wont kick on. so if i have to i can put in a two way switch and on one side have the resister for running temp and on the other side have a resister for little more then running to make the fans kick on.
really i would like to avoid all this by changing settings in ceddy to make it idle right. so if anyone has an idle on how to do that it would be great help!!!
PS i tryed to post this in the tunning part of the forms but it would't let me thinking because this is my first thead.
thanks for the help!!!
