Inkdlyfe
- 438
- 7
- Feb 23, 2016
Summer feild,
Florida
Alright so finally got my car running again for 6 months but i had to actually remove my fic to get it to run, not sure why but with it connected it wouldn't get spark or fuel, after removing it the car runs fime hits boost idles alittle rich bht that's about all, the only issue I ran into was map sensor hi out put cell, NOW can I run the car with out a fic ? The car as of now is on stock yellow top injectors not my 880 like usual but i do have a aftermarket fpr, can I run the car like this or is it not heathly, the fic is getting worked on and if it is bad that's gonna be 300+ to fix, so is it ok to run it or should I wait or would it even be ok to drive it about 5 miles to get it home
70mm turbo
38mm waste gate
Boost contoller
Triple core IC
greddy bov
255 pump
There are some of the mods the motor is fully buillt also 8.8.1 compression
70mm turbo
38mm waste gate
Boost contoller
Triple core IC
greddy bov
255 pump
