Feal 441 Coilovers
Posted by Feal Suspension, Oct 20, 2016
Please Support Feal Suspension
  1. Feal Suspension
    Feal Suspension Supporting Vendor
    7
    43
    Joined Jun 5, 2009
    Ontario, California
    We have successfully created a coilover solution that is very well priced and offers unsurpassed performance. The Feal 441 Coilover is a one-way adjustable monotube damper equipped with a genuine Japanese Swift spring. We are confident that our valving profile will yield a very comfortable yet great performing ride for your car. We have spent countless hours testing and are pleased to offer the Feal 441 Coilover kit to you.
    Feal 441 kits are also available in various specs below:
    Max Travel 441 (long stroke, lift option)
    Road Spec 441 (custom valved)
    Drag Spec 441 (record holder for fastest Subaru Legacy in USA)
    Specs:
    o One way adjustable, 30 click spectrum
    o Monotube
    o Japanese Swift springs
    o Assembled in house, U.S.A.
    o Rebuildable and revalvable in house, U.S.A.
    o Independent height adjustment
    o Teflon injected spherical bearing top mounts front and rear (MacPherson applications)
    o Aluminum top mounts
    o Camber adjustable front top mounts (MacPherson applications)
    o Corrosion resistant coating + Anodized aluminum parts
    o High quality low friction seals and rod guide bushings
    o High flow pistons (allows super high range of damping tuning)
    Pricing: Starting at $1350
    Applications (suggested spring rates for default 441 kits shown):
    Please contact sales@fealsuspension.com for any questions or to place an order.
    Log in/Register to remove ads
  2. 4Lurker4
    4Lurker4 Proven Member
    1,121
    19
    Joined Jan 11, 2009
    Brampton, ON, Canada
    I can attest to these things being a work of art. Bought my set for the 2g, haven't installed them yet unfortunately but you can tell they are quality parts with great adjustability.
    Loading...
    Tiki2777 likes this.
  3. gfritz25
    gfritz25 Proven Member
    37
    3
    Joined May 31, 2016
    Garden City, Michigan
    Noticed that the website says AWD, is there a FWD option available as well? Would definitely be interested if so.
    My DSM:
    1996 Eagle Talon TSi
    Street Build
    12.95 @ MPH
    Loading...
  4. 99ECLIPSEGSXDSM
    99ECLIPSEGSXDSM Proven Member
    980
    62
    Joined Aug 22, 2010
    Erie, Pennsylvania
    I run these on my autocross car and even tho I haven't had a lot of time with these at the track, I can already tell they've improved my handling dramatically.
    I would imagine it would be a matter of a spring rate change and maybe a revalve because the suspension between a AWD and FWD are interchangeable
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Autocross Build
    13.5 @ 99 MPH
    Loading...
    gfritz25 likes this.
  5. Feal Suspension
    7
    43
    Joined Jun 5, 2009
    Ontario, California
    We do have a FWD option available. The 2G are the same shocks whether its FWD or AWD, while the 1G rear shocks are slightly different. We could build either set with the same turnaround time. I will be updating our website with new part numbers today to reflect this.
  6. Feal Suspension
    7
    43
    Joined Jun 5, 2009
    Ontario, California
    Thread has been updated to reflect the new part numbers.
  7. ec17pse
    ec17pse Freelancer
    2,616
    704
    Joined Nov 1, 2008
    London, Europe
    just so everyone knows, you still offer the sphericals on the 2G still correct.
    My DSM:
    1997 Mitsubishi Eclipse GST
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  8. Feal Suspension
    7
    43
    Joined Jun 5, 2009
    Ontario, California
    Yes we do still offer spherical bearings for the 2G
  9. iugrad92turbo
    iugrad92turbo Proven Member
    10,278
    305
    Joined May 22, 2007
    Kalamazoo, Michigan
    Nice I got these on build list great product to complete my suspension build.
    Loading...
  10. ViciousLord
    ViciousLord Proven Member
    332
    35
    Joined Jul 27, 2005
    Orlando, Florida
    now I'm considering these. But I have to get rid of my never installed DG Koni/Ground control coilover system.
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
      manual
    Loading...
  11. Feal Suspension
    7
    43
    Joined Jun 5, 2009
    Ontario, California
  12. weasel1G
    weasel1G Proven Member
    121
    46
    Joined Aug 26, 2015
    Columbus, Ohio
    How much would a set of Drag Spec 441 run for a 1G AWD?
    Thanks
    Mike
    My DSM:
    1991 Eagle Talon TSi AWD
    Drag Race Build
    16g   manual
    1991 Eagle Talon TSi (sold)
    Drag Race Build
    16g   manual
    Loading...
  13. Feal Suspension
    7
    43
    Joined Jun 5, 2009
    Ontario, California
    The pricing on a Drag Spec 441 kit for both the 1G and 2G would be $1,550
  14. er82
    er82 Proven Member
    197
    21
    Joined Apr 18, 2014
    Sacramento, California
    I heard you are hotbits dealer as well. How much for the drag spec hotbits kit for 1g awd with independent compression and rebound adjustment (DT2 I think)?
    My DSM:
    1992 Mitsubishi Galant VR-4
    Street Build
      manual
    Loading...
  15. ViciousLord
    332
    35
    Joined Jul 27, 2005
    Orlando, Florida
    Can we see a picture of the actual 2g coil over with the spherical bearings?
    My DSM:
    Street Build
      manual
    Loading...
  16. ec17pse
    ec17pse Freelancer
    2,616
    704
    Joined Nov 1, 2008
    London, Europe
    1 better, here is a video
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
    Teezy, Attilas, ceedawg and 2 others like this.
  17. 90laserRSfwd
    90laserRSfwd Proven Member
    1,241
    60
    Joined Mar 5, 2007
    Manheim, Pennsylvania
    Does the 1g AWD kits have spherical top mounts? Or pillow ball mounts or whatever you call them (unsure of the correct terminology). How well is tge valvinf matched to the spring rates? Are the bodies height adjustable or just the spring base? In other words if I lower the ride height, do I lose travel as well? I'd like a semi decent ride as my car is street driven, but also want it to feel like it's on rails, at least a 50/50 split..
    My DSM:
    1992 Plymouth Laser RS Turbo
    Street Build
      manual
    Loading...
  18. ec17pse
    ec17pse Freelancer
    2,616
    704
    Joined Nov 1, 2008
    London, Europe
    The 1g will be camber plates as your are Mcpherson strut so that would have pillowballs anyway, normally any coilover company will match a specific valve rate to the desired springs choosen unless its requested to alter the valving, if you look at the pictures on all feals coilovers you will see the bodys are threaded so the body adjust the heights NOT the spring perch's as thats normally for super budget or bad systems like ground control units and no you wont loose travel because the height is lost in the body not shock length, they try to keep the shock length if they can.
    Just upgrading to their given rates will make you feel as if its much better but they can walk through it with you if you feel you need something different but be prepaired to know alot about your car in detail to get the best end results! it took me the best part of 8 months to get my info for me to choose my spring rates (not feal) but when you go into specifics and want different you have to know alot more but with basic info feal will have a good baseline to help accordingly
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  19. Dhan
    Dhan Supporting Member
    850
    84
    Joined Apr 29, 2010
    Denver, Colorado
    Do these come in sets of four only? Or can you buy front and rear pairs separately?
    My DSM:
    1990 Plymouth Laser RS Turbo (sold)
    14b   manual
    14b   manual
    Loading...
  20. Feal Suspension
    7
    43
    Joined Jun 5, 2009
    Ontario, California
    We can offer a pair of shocks, either front or rear, for $700.
  21. slowwhite
    slowwhite Proven Member
    164
    59
    Joined Oct 27, 2013
    camden, South Carolina
    FEAL also makes 442 with everything 441 comes with but you also get independent rebound and compression adjustablility if I'm not mistaken.
    As well as a 443 with the same as above plus high speed and slow speed adjustability if I'm correct.
    My DSM:
    Road Race Build
    GT30   manual
    Road Race Build
    425 whp   354 lb/ft
    1995 Mitsubishi Eclipse GSX (sold)
    Drag Race Build
    GT35   manual
    Loading...
  22. Feal Suspension
    7
    43
    Joined Jun 5, 2009
    Ontario, California
    That is correct. Our Feal 442 kit is 2 way adjustable with independent compression and rebound adjustment and starts at $2500.
    The Feal 443 is a 3 way adjustable kit with separate low speed compression, high speed compression, and rebound adjustment for $5500.
    iugrad92turbo and GSXbooster like this.
  23. Ludachris
    Ludachris Founder & Zookeeper
    3,417
    339
    Joined Nov 12, 2001
    Roseville, California
    For what it's worth, the 441 kit I ran on my 2G AWD was solid. Not too harsh at all for a daily driver, very compliant, though I didn't have the car slammed like some people do. And yes, they have the proper spherical bearing upper front mounts, which you don't see on most 2G kits, so you don't have to worry about the negative effects of the spring sitting directly on the upper mount.
    There aren't a lot of suspension companies producing coilover kit options for this platform anymore, and most of the ones out there are extreme budget options that have no R&D invested in this platform outside of fitment. It's nice to see Feal stepping in and offering these kits with flexible options for different budgets, with the proper upper mounts for the 2G.
    My DSM:
    1997 Eagle Talon TSi AWD (sold)
    Street Build
    16g   manual
    1991 Mitsubishi Eclipse GSX
    Road Race Build
    12.450 @ MPH
    Loading...
  24. Feal Suspension
    7
    43
    Joined Jun 5, 2009
    Ontario, California
  25. Vegas smith
    Vegas smith Proven Member
    1,770
    700
    Joined Dec 2, 2002
    Houston, Texas
    Already saving up for my set. Birthday is in late April so have one ready for me!
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    16g   manual
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory White Shed Speed
